> head swap, 4age head on a 7afe
post Jan 25, 2005 - 11:19 AM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
what head will best fit on the 7afe block? what modifications are needed? can i use the 4age distributor? please, any help will be much appricated...
-DMC
Replies (1 - 13)
post Jan 25, 2005 - 1:39 PM
FallenHero
Joined Dec 26, '02
From Alabama
www.club4ag.com Go to the tech section. Also, Kwanza and I have had MANY discussions on this subject on these forums. The info is all here, I just don't feel like searching for it.
The 4a head fits the 7a block with no mods. If you use the stock 7a bottom end though, your compression will be hella low. Yes, 4ag dizzy, and you Should use the 4a wiring harness and ECU. Preferably the .....91? geo prizm or chevy nova?, that had the MAP ECU and wiring set up. BOth cars came with the toyota 4ag small port.
post Jan 26, 2005 - 4:41 AM
H8DC3lica94
Joined Jan 29, '03
From San Diego, CA
hey bryan, let me know when you get this goin. i want to do a 20v black or silver top 7age around the summer time.
Chris Malaqui
Non-running Celica
post Jan 26, 2005 - 5:40 AM
Hanyo
Joined Aug 16, '03
From Bay area
just a noob red neck question.. lets say you take the 7a block and bolt it directly to the 4a head of a 91 nova? Would it start and run? what i'm asking is.. would the engine even come to life with the stock 4a ecu and cooling lines. COmpletely nothing else done.
post Jan 26, 2005 - 10:53 AM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
ummm just that done probley not... the 4age head will drop compression greatly... i figure ill have to custom out the harness, have to use the distrib/coil/ignition components form a 4age, sensors as well... theres gonna be a lil custom work but im sure we'll manage..
-DMC
post Jan 26, 2005 - 12:32 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Your best bet when using a 4a-ge head, is to use 4a-gze pistons. then that will make a nice set-up for a turbo. If your going N/A it would still be nice, and then just use ITB's Iv seen them on e-bay in perfect condition for $700
post Jan 26, 2005 - 12:46 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
im using the 4agze hks pistons for forkee's car
-DMC
post Jan 26, 2005 - 1:43 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Now what u guys think the dif is from using the 20v compared to the 16v. I know the geo prizm is the 16v.
post Jan 26, 2005 - 3:05 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
i dont know... im sure not much seeing as people in the ae86 comunity do that swap on a 4agze block... and ive even seen a twin charged 20v 4agzte... i think the only thing is that you will need a EMS...
-DMC
post Jan 26, 2005 - 3:40 PM
dstrbcelica
Joined Oct 24, '03
From fort smith, ar
QUOTE(thedevilmaycrie @ Jan 26, 2005 - 2:05 PM)
-DMC
[right][snapback]238609[/snapback][/right]
-dstrb
former celica owner.
post Jan 26, 2005 - 6:52 PM
H8DC3lica94
Joined Jan 29, '03
From San Diego, CA
does a 4agze tranny bolt up to a 4age or the 7afe? and would it be a smart thing to do? just thinking about having 6 speed tranny on a 7age hybrid.
Chris Malaqui
Non-running Celica
post Jan 26, 2005 - 8:31 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
not to mention it would have a lsd... and yes it will...
all a class trannys bolt up to a class engines...
all s class trannys bolt up to s class engines...
-DMC
post Jan 26, 2005 - 8:36 PM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(H8DC3lica94 @ Jan 26, 2005 - 4:52 PM)
[right][snapback]238705[/snapback][/right]
the 6 speed only came on the blacktop 20v, and they are a bit on the rare side
post Jan 26, 2005 - 8:39 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Digndoug @ Jan 26, 2005 - 5:32 PM)
[right][snapback]238549[/snapback][/right]
That's HELLA EXPENSIVE!!! The guy originally had them up for 600.00 and it did not sell. I guess his price still was too low... rolleyes.gif Anyhow... a complete kit with MAP ECU, harness, sensors, dizzy, coil/ignitor, basically everything you need sells for about 700-800 on ebay. That guy is smoking crank if he thinks he's gonna get full value for everything... Typical 4AG 20V ITBs are only about 200.00 or so...
Also... try doing a search. I've gone trhough this in fair detail quite a few times already...
This post has been edited by Kwanza26: Jan 26, 2005 - 8:39 PM
Lo-Fi Version Time is now: January 17th, 2025 - 10:42 PM
