Enthusiast ![]() ![]() ![]() ![]() Joined Sep 18, '04 From Manitoba, Canada Currently Offline Reputation: 1 (100%) ![]() |
my original switch stopped working, so i ordered a new one, it came in, and now... it still doesn't work. so i guess it's the window motor then? i dunno.. help? thanks guys
Enthusiast ![]() ![]() ![]() Joined Oct 12, '04 From Montgomery, AL Currently Offline Reputation: 1 (100%) ![]() |
girl i had the same thing happen this past summer, but i didn't get a new switch i was going to fix it and then it started working again as soon as i took the door panel off and it's worked ever sense. anyhow did you check the fuse/window relay. if not that then it might be the motor.
where is the fuse, i couldn't find it anywhere.
k i've replaced the switch, the motor... still doesn't work. i can't find the fuse/relay, and i've asked before and no one answered, but where is it
![]() Enthusiast ![]() ![]() ![]() Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) ![]() |
maybe check the switch to see if power is going to it. Make sure your window didnt get off track or get stuck. what side? passenger? if it is then see if the other drivers side makes it work. If its drivers side then see if your pass window goes down and then see if your pass side makes it go down. you can cross check them with one another.
-------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
the switch and the motor have power, it's when you connect them that they dont
Lo-Fi Version | Time is now: February 23rd, 2025 - 3:01 AM |
