> scary engine noises
post Feb 16, 2005 - 1:26 AM
Jaemus
Joined Feb 4, '05
From Sydney, Australia
hey guys
i wondered if someone could help me with a problem im having with the GT4 (gen3 3sgte)
i noticed yesterday afternoon that it was making some uncharacteristic ticking/rattling type noises as i drove home - faint, but loud enough to hear from the cabin, and only under load at low rpms.
just now, i went out and started it up, and at low revs, as i play with the throttle, it is making a noise that sounds like if you were to tap the bottom of an empty tin with a key - it makes this sound just over 1k rpm (so not at idle) and it gets higher pitched and more frequent as engine rpm's increase. its scaring me and i dont want to drive it till i figure out whats going on (for fear of making it worse).
i cant quite identify where the sound is coming from - but it seems to be anywhere around the top of the motor.
any ideas? if you need more info ill do what i can.
PS. i tried to make a sound file with my camera, but the noise which is clearly audible over the background to my ears, gets drowned out completely on the camera. *shrug
Replies (1 - 9)
post Feb 16, 2005 - 1:42 AM
shid
Joined Jan 8, '04
From LA
Aftermarket intake?
It could be lifter tick? Does the Group A 3sgte have solid lifters? If so, it sounds like they need to be adjusted
post Feb 16, 2005 - 2:03 AM
Jaemus
Joined Feb 4, '05
its totally stock
lifter tick - i thought that was audible at any rpms
post Feb 16, 2005 - 5:04 AM
Jaemus
Joined Feb 4, '05
well i got brave enough to take it for a drive
it dissapears sorta at higher rpms like 4-5k (and below 1k rpm)
the performance symptoms it is showing is the same problem i had before (missing, surging, pulling back) but MUCH worse - i was hoping was an ignition problem which i havent had time to fix yet
no check engine light, but i will pull the codes (there was a 23 and a 41 in there before from god knows how long ago)
cant see any smoke from where i sit (i did try) but the fumes smell much worse at idle.
at the end of the drive the ticking noise went away ALMOST completely - but the performance remained terrible.
post Feb 16, 2005 - 7:26 AM
somethings wrong, your ecu is retarding timing.
post Feb 16, 2005 - 10:04 AM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Change the plugs, wires, distributor cap and rotor and oil...See if that works first.
post Feb 16, 2005 - 10:09 AM
Newbie
Joined Nov 3, '04
From Colorado
Sorry for this stupid question, but what kind of fuel are you putting in?
post Feb 16, 2005 - 1:29 PM
could be anything from exhaust manifold leak, to a clutch issue.
i bought this car stethiscope from sears, it really does a great job at helping you find the source of the problem. see if you can find something like that.
i had a similar strage noise coming from my engine bay, it turned out it was coming from the clutch and throwout bearing.
post Feb 16, 2005 - 1:53 PM
sphinx
Joined Apr 10, '03
From South Central Los Angeles
QUOTE(lagos @ Feb 16, 2005 - 10:29 AM)
[right][snapback]246823[/snapback][/right]
I had that same problem, and it ended up being the same thing. The bearing.
post Feb 16, 2005 - 9:19 PM
Jaemus
Joined Feb 4, '05
98 octane fuel
a car stethescope you say... ill look around for that
i hope its not anything clutch related cos man thats gonna be a pain
Lo-Fi Version Time is now: November 28th, 2024 - 1:39 AM
