![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 8, '04 From LA Currently Offline Reputation: 0 (0%) ![]() |
Chrobis has changed his mind again (I know, I know) and wants to do the swap; you can ask him his own reasons. But anyway, here's the dealio. Its a call for help. Neither Chrobis nor I are technically inclined enough to perform this swap (Chrobis can probably wade his way through it, I couldn't do jack sh!t)
So, we're looking for someone in the socal area who wants to do the swap for us/slightly with us. We're both on a tight budget, and I'm paying for all the parts needed. Currently, here's what has to happen: 1) Removal of 5sfe engine from my car, including EGR, ECU, all the wiring 2) Removal of automatic transmission from my car. 3) Removal of the entire exhaust from my car. 5) Distributer problem checked out before removal of 3sgte from Chrobis' car 4) Removal of Chrobis' 3sgte from his car, including the ECU, all the wiring 5) Removal of the transmission 6) Removal of the entire exhaust 7) 5sfe into Chrobis' car 8) New transmission, clutch, into Chrobis' car. 9) My old exhaust onto Chrobis' car 10) 3sgte needs to have AFM replaced 11) Distributer problem fixed 12) 3sgte into my car 13) Manual transmission into my car 14) Chrobis' exhaust onto my car. yeesh, a 14 step list. Also, we'd need two engine hoists and a place to do this ![]() He wants to get this done and over with ASAP, and the earliest I can really be without my car for an extended period is the 19th. Is anyone willing to help? Does anyone have the garage space we need? or two engine hangers? What are your thoughts on this? How long do you think it will take? --Sean This post has been edited by shid: Mar 3, 2005 - 2:06 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) ![]() |
man i want a 5 speed so bad, i missed an insane deal. Good luck man. Keep us posted
edit: i plan on doing my 5 speed swap, but it might not take place till winter 2005-2006 so i can source the best parts possible at the best prices. im in no real rush, ill finish exterior and suspension this summer though. This post has been edited by Akimbo: Mar 3, 2005 - 1:46 PM -------------------- |
Alternatively, Chrobis could drive the car down here ASAP, and someone can track down the sputter problem and then pull the engine, transmission and exhaust by the 19th. Then I'll come in, we'll slip the 5sfe into Chrobis car, and he can be on his way before the 3sgte is in my car. (Since I've been told putting a 5sfe back into his car wouldn't take very long at all)
This post has been edited by shid: Mar 3, 2005 - 1:47 PM |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) ![]() |
Your plan seems very ambitious - actually close to unrealistic given the parameters. Nevertheless, I wish you guys the best of luck.
-------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
The timeframe is the real unrealistic thing- the swap shouldn't all that bad. All the wriing is done and being preserved, and with the exception of the new transmission it's a straight swap.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) ![]() |
like i said in that other post
im down to help 19th, thats the first day of my spring break. so thats perfect for me. you only need one engine hoist, but get a bunch of wood pallets and blocks to set the engines down on. swaping in the 5sfe can be done in one day, if need be, but checking things on the 3sgte will slow things down a bit. i will be able to bring tools and a jack with stands. as for a hoist, a friend of mine has one, but im not sure if he will let me borrow it for use on a strangers car, lol i'll be in for the duration i guess, nothing better to do, lol. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 4, '04 From Northern New Jersey Currently Offline Reputation: 2 (100%) ![]() |
good luck to u guys... i'd be happy to help but 1) i dont know $hit and 2) im on the east side...
![]() ![]() -------------------- ![]() ..(formerly daily driven) 3S-GTE powered celica currently set @ 12psi.. |
![]() Enthusiast ![]() ![]() ![]() Joined Jan 1, '03 From LB gizzie, cali Currently Offline Reputation: 0 (0%) ![]() |
I might be able to help you guys...when are you guys getting started?
and where are you guys planning to do all of this? -------------------- [color=#FF0000] I MISS MY RED BABY =(
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Nov 15, '02 From Vidor, TX Currently Offline Reputation: 1 (100%) ![]() |
ok ok ok bring the cars to my house... however we will need to start early if you wanna be able to drive the cars home by sunday night...
i have everything we will need... -DMC |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 10, '03 From South Central Los Angeles Currently Offline Reputation: 0 (0%) ![]() |
Shid, I don't have a garage to do it at, but I can honestly tell you that everything can be done in one weekend. But you need to have the distributor fixed/changed by then. Same with the AFM.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) ![]() |
too bad i'm all the way in TN. i did all that w/ my car, and a car in cincy, and it only took me 2 days (that's including the driving), and that was doing most of the work by myself...
![]() i'd love to help...but it's just not in the cards for me to come out there. ![]() -John- -------------------- |
sounds like a whole lot of work just because you are sick of having broken afm.
![]() Enthusiast ![]() ![]() ![]() Joined Aug 29, '02 From San Diego CA Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(thedevilmaycrie @ Mar 3, 2005 - 5:14 PM) ok ok ok bring the cars to my house... however we will need to start early if you wanna be able to drive the cars home by sunday night... i have everything we will need... -DMC [right][snapback]252876[/snapback][/right] dang cant beat that offer ![]() |
Lo-Fi Version | Time is now: February 20th, 2025 - 1:52 AM |
