> strange sound from front right
post Mar 12, 2005 - 8:47 PM
soltrain
Joined Aug 19, '04
From Berkeley
This just started about two days ago.
When the car is moving (not necessarily under acceleration) I'll hear this soft tapping, clunking from the front right side. It doesn't occur in regular intervals, and is pretty soft, I can only hear it if I turn off the radio.
The sound doesn't seem associated with bumps or turning the wheel, as I can hear it when I'm just going in a straight line.
I've just had the ST sway bars put on, but from what I've read, this doesn't seem like the sound it would make if they were rubbing.
Any ideas?
loose control arm? CV joint?
This post has been edited by soltrain: Mar 12, 2005 - 8:50 PM
Replies (1 - 15)
post Mar 12, 2005 - 9:30 PM
aznxrussel
Joined Oct 22, '02
From irvine
check for any grease on the wheel....chances are it will be the axle
This post has been edited by aznxrussel: Mar 12, 2005 - 9:32 PM
post Mar 12, 2005 - 11:23 PM
macavely
Joined Nov 4, '02
check ur battery tray ....
post Mar 13, 2005 - 1:32 AM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
battery tray is on the front left, at least on my ST it is.
post Mar 14, 2005 - 12:23 AM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
its a mouse trying to get out!
post Mar 14, 2005 - 12:52 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
no no, its not the mice... its our pigeons powering our engine. i was told that my car is powered by pigeons before i put on the exhaust and are intake. hilarious stuff. cept for it was from a friend who owns a straight 8 truck that has like a ... huge lift and nice exhaust.
post Mar 14, 2005 - 5:05 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
If it is like a clicking sound that is independent of the engine rpm, and seems to increase and decrease with just vehicle speed (not engine rpms) then it might by your wheel bearing. I just had to replace one of mine.
post Mar 14, 2005 - 5:54 PM
erics1one
Joined Aug 27, '04
From Orange County, CA
CV Joint, Wheel Bearing, or Brake Assembly
post Mar 15, 2005 - 7:29 PM
soltrain
Joined Aug 19, '04
From Berkeley
It's definately independent of RPM. I can check if it's the wheel bearing by jacking up the car and spinning the wheels ya?
For CV joint, do I check the boot? Or was that where I jack up the car, take the wheel and try to move it around?
post Mar 17, 2005 - 5:20 PM
94GT
Joined Feb 25, '04
From Fairfield, CA
I tried that method and it didn't work for me. The mechanic told me the car has to be under load to make the noise (i.e. weight on the wheels). Mine was the wheel bearing.
post Mar 17, 2005 - 5:47 PM
LatinKraze
Joined Oct 22, '03
QUOTE(aznxrussel @ Mar 12, 2005 - 6:30 PM)
[right][snapback]256575[/snapback][/right]
Happened to me. Check the axle first. The mechanic said he had worked on two other sixth gens that had 2 loose bolts. My two bolts fell out and I got stranded. frown.gif
post Mar 21, 2005 - 3:09 AM
juBz86
Joined Aug 18, '04
From NJ
i had a similar problem. sometimes when i accelerated from a standstill or broke to a standstill, i would hear this loud popping/crunching sound from the front right side. it ended up my control arms. they needed 2 be tightened.
post Mar 21, 2005 - 6:48 AM
soltrain
Joined Aug 19, '04
From Berkeley
didn't see any grease on the wheel, I'm goin to the mechanic tommorow to see whats goin on
post Mar 23, 2005 - 10:04 AM
bloodrain
Joined Mar 3, '05
From Hollywood, FL
I have the same problem (i think) its like a click/grind sounded mixed, and it only happens every now and then. Tell me what you find out.
To live, is to suffer
post Mar 24, 2005 - 1:10 PM
Consynx
Joined Dec 25, '02
From Pittsburgh/Clairton, PA
post Mar 25, 2005 - 8:16 PM
soltrain
Joined Aug 19, '04
From Berkeley
Welp, it turns out it was the ST sway bar that I just had put in. I thought I was getting a newly designed 'no rub' bar (the old bars rubbed and caused this sound), but I didn't.
On the downside, it looks like my CV boot is bust because there's grease all over the axle. Shop quoted me 200 something to replace. Ug.
Lo-Fi Version Time is now: February 18th, 2025 - 8:59 PM
