![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 9, '05 From Oakland, Cali Currently Offline Reputation: 46 (100%) ![]() |
hi all,
just want to know something abut overdrive. i noticed when im at a full stop, turning o/d off (lights orange on dash), seems to go more smooth....but when i hit around 35 mph...motor starts running hard...when i engage o/D its all smooth...whats the deal between it anyways?....newbie here.... ![]() -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) ![]() |
O/D is a gas saving feature, it makes the motor run harder when its off because the car thinks you want more HP, not gas milage.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) ![]() |
welcome to the site. and from now on if you could post your topics in the proper forums it would help us out
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Hollywood, FL Currently Offline Reputation: 0 (0%) ![]() |
any1 know exactly how O/D works? And why would it be called "Over Drive" if you want to save gas, wouldnt it be Under Drive?
-------------------- To live, is to suffer
To survive, thats to find meaning, in the suffering.... ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) ![]() |
let me see if i can explane this... while my brain is semi funtional right now...
Over Drive... is another gear in ur tranny .... by disabling it... u tranny goes back down into 3 gear and lets ur engine rev higher... while it is one .. at higher speeds.. the tranny shift into high gears as lower engine revs... wich makes for a smoother ride and saves on gas.... and as for the name ... don't know... there are a lot of things on cars.. that i feel are named wrong.. -------------------- |
QUOTE(macavely @ Mar 18, 2005 - 12:20 AM) let me see if i can explane this... while my brain is semi funtional right now... Over Drive... is another gear in ur tranny .... by disabling it... u tranny goes back down into 3 gear and lets ur engine rev higher... while it is one .. at higher speeds.. the tranny shift into high gears as lower engine revs... wich makes for a smoother ride and saves on gas.... and as for the name ... don't know... there are a lot of things on cars.. that i feel are named wrong.. [right][snapback]258862[/snapback][/right] thanx jus thought i wanna kno the answer for the car's sake =D -------------------- ![]() |
thanks for the explanation. Ya there are alot of things named wrong, headlights, tail lights, over drive, you drive on a parkway and park on a drive way, go figure :-p
it also changes the shift points, atleast in my GF's 7th gen that is.
![]() Enthusiast ![]() ![]() ![]() Joined Sep 17, '03 From Tampa FL Currently Offline Reputation: 1 (100%) ![]() |
I used to leave it off when I was driving around town. My car is very loud and with higher rpms it was louder. after a month or so with it off my car started acting funny and the trans was acting up. I turned it back on and the probs went away. I was not redlining it either.
-------------------- -97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre (GOT LIFT?) |
Lo-Fi Version | Time is now: February 20th, 2025 - 5:00 AM |
