> 10W6 Vented Through the Rear Deck, Figured you coupe owners might like this
post Mar 19, 2005 - 4:01 AM
Since I got my coupe almost four years ago, I've always envied how the hatchbacks have no rear deck in the way to keep lots of the bass from subs in the trunk. Today, after a couple days of working a couple hours a day, I finally remedied the problem.
The answer is a vented box, with the vent going through a hole cut in the rear deck, in my case, a JL Audio 10W6 in a 1 ft^3 vented box tuned to 34 hz.
First, you plan your box. I took measurements, thought about what I wanted, and then used LinearTeam's WinISD software for my box-planning, and came up with a design that was originally tuned to 32 hz.
That's WinISD...a really nice program available for free.
http://www.linearteam.dk/default.aspx?pageid=winisd
Then I cut the hole where I planned for my vent to be. I used a sawzall, which was no easy task due to the large size of the sawzall and the small working dimensions inside the trunk and cabin of the car.
I then built the box out of .75" MDF...no pics of the build process, but you can see it above inside the trunk, un-carpeted, and held in by a tow-strap for testing purposes. That battery mount and cable setup is temporary as well, for testing purposes. wink.gif
There it is from the inside of the car. I chose to point the sub towards the backseats, because it protects the sub from stuff flying around in my trunk.
"But Coomer, subs always sound bad when they're firing towards the backseats in Celica coupes."
They often do in a sealed box, but this isn't a sealed box. Due to the nature of a vented box, most of the air is moved by the vent, rather than the outside surface of the sub, so although the sub moves some, it doesn't produce enough output going forward to rattle the thin metal behind the backseat and make it sound bad.
Bad pic, but you can see the vent in the box pointing through the hole in the rear deck. The vent is simply 3"(inner diameter) PVC pipe, 14" long. I had to cut the pipe down 2"(from 16") in order to get it to fit in the car, so it raised the tuning frequency to 34 hz. Note that the number of inches removed from a port does not equal the number of hz raised in most cases...it just happens to in my case.
While I was at it, I figured I'd relocate the JBL BP300.1 that provides an estimated 225 watts to the 10W6. I know, it's a bad choice of a box for this amp, because the amp has no subsonic filter. I'll just be careful, and if the sub blows, at least I'm only out the $30 that I paid for the sub. Anyway, the amp used to sit on top of my old sealed box, but now it'll be hidden away behind that side panel. On the other side of the car, my amp for my front stage sits behind the other side panel.
Sound Impressions
As far as SQ goes, the box actually does not sound as good as I'd hoped it would. The bass is sloppy, and I think that my box is tuned too high. Lots of rock songs don't sound near as good as they did with my 1 ft^3 sealed box and the same sub and amp, though most rap songs sounded pretty good with the vented setup.
As far as SPL though, this box setup blows away the SPL performance of the former sealed setup(Even when I had the seats down with the sealed box.) No longer is the bass absorbed and blocked by the trunk, but instead, it shoots right through the rear deck and off of the rear window, making the setup louder. Not only does it make it louder, but immensely reduces the rattles in the trunk. My trunk didn't rattle much at all before because of all my sound-deadening, but the plate would sometimes rattle. Now there are NO rattles outside the car at all, even with the windows up, trunk closed, and the volume up pretty loud.
Also, vented boxes will provide three extra decibels of output over a sealed box with the same power, so that makes the setup even louder.
Overall, I couldn't live with this setup on a daily basis. It's just too sloppy for me, but it's a good start. My plan is to build another vented box, but use a square L-shaped port instead, and tune the box to 29 hz or so. Maybe I'll mess with the box airspace as well to get better SQ. smile.gif
Attached Image Attached Image Attached Image Attached Image Attached Image Attached Image
Replies (1 - 5)
post Mar 19, 2005 - 2:52 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
very nice Coom. very nice.
Team 6gc 2005
post Mar 19, 2005 - 3:57 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
How many freakin colors do you have in that car ?
Nice Job coom
I will return one day.
post Mar 19, 2005 - 11:28 PM
ghostdog
From ny to philly
damn coomer, I didn't understand half of what you said but thats a nice setup. pioneering better acoustics for all us coupe owners
post Mar 20, 2005 - 3:32 AM
tomazws
Joined Oct 30, '04
From So Cal
QUOTE(defgeph @ Mar 19, 2005 - 8:57 PM)
[right][snapback]259558[/snapback][/right]
LOL!!!
Dude Coomer, everytime I see your car I ask myself the same question lol
I love what you did with your engine bay though, it's very sweet. I can't wait to see your finished pics of your trunk!
post Mar 20, 2005 - 4:28 AM
Scarrell
Joined Nov 8, '04
From Carmi, Illinois
you could just build a vented box, without the port to the rear deck. but just leave the hole so the bass goes into the cars cabin... this is also a good idea for guys running sealed enclosures... well for any setup.... it allows more air into the cabin and well be louder inside..
i want a stereo so loud, it blows womens clothes off.
TrickedOutS2000: I just opened a box that arrived on my doorstep cuz i thought it was my H.U.
TrickedOutS2000: it was a vibrator my dad bought
scarr3ll: WHAT THE ****?!?11
TrickedOutS2000: yeh
TrickedOutS2000: for my mom im guessing
TrickedOutS2000: but yeah
TrickedOutS2000: eww
TrickedOutS2000: so
TrickedOutS2000: ****ing
TrickedOutS2000: wrong
My Cardomain Page.
Car Audio Central
msn: jared_s_c@hotmail.com
aim: Scarr3ll
Lo-Fi Version Time is now: November 28th, 2024 - 11:42 AM
