> Cooling, Oil and water temp
post Mar 21, 2005 - 12:24 AM
1995st204
Joined May 25, '04
From Columbus Ga
I just changed me radiatior on my gt and it is much thicker now because it is the radiator with the auto tranny cooler on it. At first i was running prestone 50/50 mix in it and now i am running the Advance auto 50/50 crap and my car is getting much hotter. i noticed this when i ran my car on a dyno and put 150 to the ground when the oil was around 200 degrees and when it got up around 250 it it only put 120 to the ground. I read in the latest import tuner that optimum oil temp is between 200 and 220. I was wondering what all i could do to get the temp down. Does anyone have any suggestions?
Replies (1 - 9)
post Mar 21, 2005 - 12:31 AM
jgreening
Joined Jan 17, '04
From Illinois
150 whp on a 5sfe? What mods do you have?
As for your question, you can install an aftermarket oil cooler. Try newcelica.org. Many gts 7th gens get them. However, you shouldn't need one for the 5sfe.
post Mar 22, 2005 - 1:14 AM
1995st204
Joined May 25, '04
From Columbus Ga
all i have is intake and full exhaust. It suprised the crap out of me. I know that the gt's have a factory oil cooler but my oil is still going over 220 degrees.
post Mar 22, 2005 - 1:28 AM
Drocay
Joined Oct 3, '02
From Va Team 6gc
Team 6gc 2005
post Mar 22, 2005 - 10:54 AM
97GTinKC
From KC
Did the dyno shop have fans to direct air into the radiator? could be you are just stressing the cooling system if there is not enough airflow across the radiator.
Otherwise, you should run a full synthetic oil like Amsoil, its been known to reduce oil temps switching to full synthetic.
post Mar 22, 2005 - 10:59 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE(Drocay @ Mar 21, 2005 - 11:28 PM)
[right][snapback]260530[/snapback][/right]
I agree.
150 to the wheels 5sfe. Not possible.
Member of Team 5sfTe
post Mar 28, 2005 - 12:37 AM
1995st204
Joined May 25, '04
From Columbus Ga
150 is possible because I have a dyno sheet to prove it. It was when my oil was still cold and my entake wasnt sucking hot air from off the engine. Me and three other guys saw it.
The fan was blowing on the radiator but once it got hot all it did was loose power. I am trying to find a decent oil cooler and trying to get cooler air to my intake. I am also going to switch to synthetic oil.
post Mar 28, 2005 - 1:07 AM
946thGenGT
Joined Oct 4, '04
QUOTE(1995st204 @ Mar 28, 2005 - 5:37 AM)
[right][snapback]263030[/snapback][/right]
Can you scan and post the dyno sheet for us skeptics?
post Mar 28, 2005 - 1:18 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
150 celica at our finger tips... what did i do buying an ST when i shoulda bought a GT , 40 more horse power *rolls eyes*
post Mar 29, 2005 - 8:58 AM
1bwilson
Joined Aug 30, '02
From Maryland
QUOTE(1995st204 @ Mar 27, 2005 - 10:37 PM)
Please post a pic of your car on the dyno if you have one and lets see the dyno sheet.
Sorry to seem like I dont believe you but Ive been around these boards for a VERY LONG time and no one yet has put down 150 to the wheels with even a highly modded 5sfe. As amatter of fact (if Manny would jump in here, HINT HINT rolleyes.gif ) with the #'s, your going to be running out of fuel before the 150 mark.
Lo-Fi Version Time is now: November 29th, 2024 - 5:30 AM
