> Sidemarkers help, they dont work
post Mar 22, 2005 - 11:50 AM
305BlacKGT
Joined Mar 17, '05
From Miami, Florida
My old sidemarkers burnt out so i bought the clear ones to replace then. When i tried to turn them on they didn't work. Does anyone know if this is a problem with the wires or a fuse? Only the sidemarkers are being affected.
Replies (1 - 4)
post Mar 22, 2005 - 12:10 PM
shid
Joined Jan 8, '04
From LA
I know this is a stupid question, but did you replace the bulbs? If not, then you check the fuse. Then you check the wiring plug right behind the sidemarkers, then it's a wiring issue if thats not it, and you've got a lot of wire to chase.
Changing the housing is just a superficial change, its not gonna make a burnt bulb or bad wiring suddenly better
This post has been edited by shid: Mar 22, 2005 - 1:37 PM
post Mar 22, 2005 - 12:16 PM
Yeah, those bulbs are probably the most common bulbs to burn out on sixth gen. Celicas...I'd check to make sure they're not burnt out.
post Mar 22, 2005 - 5:02 PM
305BlacKGT
Joined Mar 17, '05
From Miami, Florida
the bulbs came with the sidemarkers and are brand new. im guessing its the wires that i have to check.
post Mar 22, 2005 - 6:50 PM
shid
Joined Jan 8, '04
From LA
Yeah, then just to make sure you didn't unplug the wiring harness a couple inches away from the bulbs.
Lo-Fi Version Time is now: November 24th, 2024 - 10:43 AM
