> driving impression, suspension issue
post Mar 22, 2005 - 9:34 PM
TTE
Joined May 19, '03
From NJ
I have this issue with the car for the last couple months that when driving on the straight I have a feeling like driving in strong wind, it throws car to the right and left all the time without me turning steering wheel plus there is that little sound coming from the lower front I can't even tell if its right or left and it is really a quiet one. My friend took it for a ride and said that he didn't heard anything and it drives fine but I know its not. Car was serviced with new axels, new tires and allignment a mounth or two ago. Anyone had smth like that before? Any ideas where to look for?
Replies (1 - 7)
post Mar 22, 2005 - 9:58 PM
LewFX
Joined Jan 28, '05
From Redondo Beach, CA
low air in tires?? blown strut?
post Mar 22, 2005 - 10:15 PM
TTE
Joined May 19, '03
From NJ
QUOTE(LewFX @ Mar 22, 2005 - 7:58 PM)
[right][snapback]260974[/snapback][/right]
I forgot to mention that struts are new and tire preasure was checked as well.
post Mar 23, 2005 - 11:07 AM
could be your ball joints.
im having a problem with my car pulling to the right when i give it some gas. does yours happen when u are giving it gas, or just cruising at the same speed?
post Mar 23, 2005 - 11:15 AM
TTE
Joined May 19, '03
From NJ
QUOTE(lagos @ Mar 23, 2005 - 9:07 AM)
[right][snapback]261199[/snapback][/right]
It is happening only when cruising.
I tend more to power steering problems. Anyone knows how to check ball joints, steering knuckle and steering linkage
post Mar 24, 2005 - 3:03 AM
Blakout16
Joined Jul 3, '04
From Yakima, WA
have u checked ur powering steering belt?
post Mar 25, 2005 - 1:06 PM
TRD6GC
Joined Nov 17, '03
Make sure your sway bars are hooked up good too, that may cause a little but of a problem like that. Take it to a shop and have them put it up on a lift and look around.
post Mar 26, 2005 - 4:35 PM
TTE
Joined May 19, '03
From NJ
After check up mechanic told me that inner tie rod need to be replaced. I hope he is right.
Lo-Fi Version Time is now: February 18th, 2025 - 8:29 PM
