is something wrong?, noises from 5sfe |
Mar 26, 2005 - 10:03 PM |
Enthusiast Joined Jan 20, '05 Currently Offline Reputation: 0 (0%) |
sometimes when i turn my car on and leave it to warm up a little i hear a little "creeking" sound that seems to churn over and over until i actually press the throttle a little.
it almost sounds like the belt turning and turning, only the sound it makes is more like a squeeky door? it doesnt matter if its cold or hot outside it still does it. anybody had this problem before? or know what it is? |
Mar 27, 2005 - 2:05 PM |
Enthusiast Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
tighten the belts, maybe?
Mar 30, 2005 - 4:10 PM |
Enthusiast Joined Feb 22, '05 From Vegas Baby!! Currently Offline Reputation: 0 (0%) |
Can you determine where the noise is coming from on the engine? I know that this sounds a little obscure. On my old 90 GTS, it had a 5SFE, and the waterpump went-out on it. But before it went-out, it was making a noise like the one you described.
I was told by a Toyota mechanic , that this is one of the tell-tale signs that your waterpump is about to go out. You usally have around a hundred miles before it craps-out. When the bearings start to wear-out around the lever, it'll start to make the noise. One of the benefits of having a mechanical than an electrical one I guess. This post has been edited by cmorty: Mar 30, 2005 - 4:11 PM |
Lo-Fi Version | Time is now: November 25th, 2024 - 2:29 AM |
