> oil pressure sender switch, where is it?
post Mar 30, 2005 - 3:28 PM
where on the 7afe is the OEM oil pressure sender switch located so i can hook up my oil pressure gauge
Replies (1 - 7)
post Mar 30, 2005 - 7:54 PM
RedSunCelica
From San Diego CA
under the alternator a little to the right on the block of the motor. ill post a pic if you need it.
post Mar 31, 2005 - 12:15 AM
ok i found it and put in the new presure gauge
but for sum reason its really not doing what it should
the stock sensor (one wire)
i cut off and spliced that wire with the gauge wire and hooked them up to the new sender switch
then ran it to the gauge
now the gauge worked for about 5 min while it was sitting in my drive way then when i started to drive it dropped the oil light (oem) on cluster?
but its WAAAY full and i could feel any leaks when i stuck my hand down there?
but i'll have to wait to see it in the morning to double check
and make sure nothing is leaking
does anyone know if i have to get a T- connection and use the stock sender switch in conjunction with the gauge?
post Mar 31, 2005 - 12:42 AM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
yes you do and i believe the thread is 1/8" bspt thread
post Mar 31, 2005 - 10:33 AM
nik
Joined Sep 30, '02
here is a pic with a T fitting
post Mar 31, 2005 - 11:14 AM
st_celica_killer
Joined Sep 23, '04
From fresno
is it working now?? cauz i need it to install mine on my car also!!!!!!!!!
post Mar 31, 2005 - 11:26 AM
nik
Joined Sep 30, '02
my oil pressure guage came with a pressure sending unit that i installed in my oil relocation kit along with a oil temp probe
do you guys have any pics of your stuff??
post Mar 31, 2005 - 7:12 PM
yea i used that pic yesterday
woot for thinking on my feet to use your HOW TO
but i got the stuff from HD today
i'll install it tomorrow afternoon
Lo-Fi Version Time is now: November 28th, 2024 - 9:50 PM
