> altezza motor, fitment
post Apr 4, 2005 - 3:15 PM
juBz86
Joined Aug 18, '04
From NJ
hey i was just curious. i was roaming around ebay and found the beams 3sge black top and i was wondering if these would drop right in and bolt up to the gt tranny.
ebay motor 1
ebay motor 2 (i dont think this ones a 3sge)
i need enlightenment.
Replies (1 - 19)
post Apr 4, 2005 - 3:16 PM
Mechanically yes, electrically...i'd have nightmares.
post Apr 4, 2005 - 3:26 PM
BLADDER_MASTER
Joined Dec 8, '04
You're better off getting the BEAMS 3S-GE that came in the ST202 Celica's.
post Apr 4, 2005 - 3:51 PM
for 4grand i would go with a swap thats more documented. it would take a lot of custom work to get that motor to sit right and i wouldnt recomend it unless you have done swaps like this before.
post Apr 4, 2005 - 3:54 PM
thedevilmaycrie
Joined Nov 15, '02
From Vidor, TX
i dont know... the black top is duel vvt... sooo who know... id do it...
-DMC
post Apr 4, 2005 - 4:14 PM
Drocay
Joined Oct 3, '02
From Va Team 6gc
if i got it i would do the clip, but that one had front end accident do u think its worth it.
Team 6gc 2005
post Apr 4, 2005 - 4:50 PM
DamDirtyApes
Joined Apr 22, '04
From Rhode Island
do it, do it
post Apr 4, 2005 - 4:58 PM
orvillescelica
there will be problems no doubt!! Much harder than any 3sgte swap. But if you have the money and time i would definatly go for it. Its a BEAMS black top!!!!
post Apr 4, 2005 - 5:05 PM
macavely
Joined Nov 4, '02
be original ... or be like everyone else...
post Apr 4, 2005 - 5:38 PM
chucho
Joined Mar 23, '03
From New Orleans
QUOTE(macavely @ Apr 4, 2005 - 5:05 PM)
[right][snapback]266491[/snapback][/right]
post Apr 4, 2005 - 6:48 PM
macavely
Joined Nov 4, '02
QUOTE(chucho @ Apr 4, 2005 - 5:38 PM)
[right][snapback]266507[/snapback][/right]
yup thats to point...to many people on here are scared little biiootchess. and wont be the frist ones to put there foot in the water... and are even quicker to tell someone not to try something cause it hasn't been doen before... all up in the cool-aid and don't even know the flavor ..
post Apr 4, 2005 - 6:50 PM
orvillescelica
once there is an original... it will be very very very hard to be a follower with this one. The BEAMS black top is not an engine you come across very often.
post Apr 4, 2005 - 6:54 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
"fit" is a very very bad word to use. "fit" is easy... "work" is hard. The BEAMS blacktop is always from a rwd platform, so it requires a bit of work to make things work. It'll drop in and bolt up ok... satisfying the "fit" requirement, but wiring, plumbing, everything is gonna be custom.
post Apr 4, 2005 - 7:16 PM
macavely
Joined Nov 4, '02
the hard the work and great the statifaction u'll have once everthign is doen.... and hard is only messured by a preson want to do something... something could take along time to figure out but not hard to do .. just takes a while to do right...
post Apr 4, 2005 - 8:55 PM
my theory on these never before done swaps is that if you have to ask about it, then you are not ready to do it. you can have all the people on a msg board cheering you on, but in the end its going to be you and that motor in a garage.... and you will have no one to refer to when a problem comes up.
at least with the 3s swap, if you get stuck, there will be enough people on this site that can help you finish your project.
post Apr 4, 2005 - 9:12 PM
macavely
Joined Nov 4, '02
just cause a person ask questions doesn't mean they can't do something... asking questions is how u get the answers ur looking for and if some one doesnt' have the answers.. u do what has been done by every person that has been the first to try something... and that is try it urself and find what works and doesnt. ..
with and engine swap ur not lunch the car up into space .. ur just doing a swap ... if u take ur time and learn the basics before anything else.. then how the little extras work ... u'll be fine...
post Apr 6, 2005 - 12:41 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
how much HP is a Beams blacktop pushing?
Matt
**** Photobucket
post Apr 6, 2005 - 12:57 AM
should be the same as our is300. about 195hp at the crank, but thats just my guess.
post Apr 6, 2005 - 1:15 AM
macavely
Joined Nov 4, '02
i think the IS300 has more HP then the altezza ... i hope it would seeing one is a 4clynder and the other a 6 ..
post Apr 6, 2005 - 1:59 AM
BLADDER_MASTER
Joined Dec 8, '04
QUOTE(macavely @ Apr 6, 2005 - 1:15 AM)
[right][snapback]267205[/snapback][/right]
Yah, a massive 5HP more.
Lo-Fi Version Time is now: November 28th, 2024 - 7:59 PM
