![]() Enthusiast ![]() ![]() ![]() Joined Apr 4, '05 From ST PAUL, MN Currently Offline Reputation: 3 (100%) ![]() |
what should i do if i want to have a better pull on 3rd gear.. im running a custom t-25 turbo in my car and yeah should i switch to a real ct26 turbo and just put away my custom set up. i pull hard on 1st and 2nd but i lose total power on 3rd and up..what should i do. switch to real ct26 or just keep want i got. i have a 95 gt 5sfte.
This post has been edited by RUNNIN-LOW: Apr 6, 2005 - 11:05 PM -------------------- ![]() |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(RUNNIN-LOW @ Apr 7, 2005 - 4:05 AM) what should i do if i want to have a better pull on 3rd gear.. im running a custom t-25 turbo in my car and yeah should i switch to a real ct26 turbo and just put away my custom set up. i pull hard on 1st and 2nd but i lose total power on 3rd and up..what should i do. switch to real ct26 or just keep want i got. i have a 95 gt 5sfte. [right][snapback]267536[/snapback][/right] t3? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) ![]() |
agreed, t3 or hybrid is wut u need. hows the t25 thats wut i've been looking at for my 7afe either that or a t28bb
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
man ill tell you the one i have man its spools up fast. if i floor it it spool about 1300 rpm..and yeah now you know why i pull so hard on 1st and 2nd but see im planning on getting rid of it for a ct6 im just planning to change my set up.. but im still thinking about putting a t3 on like you say too. and yeah i want more power and people say i need a bigger turbo cause i have such a hugh motor compare to a small little turbo which isn't pushing enough power. but yeah its great man.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) ![]() |
do you pics of your set up? cause i'm currently getting parts to turbo charge my 5sfe too. i'm gonna use the ct26 dual entry
yeah i just have to redo my pictures and post it up on my profile.. so yeah..it will be up pretty soon
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
umm don't bother with ct26 if you have to upgrade might as well do it right
and get a T3 thats what i'm goin with to start? |
alright then ill see what will happen im just woundring what will bring out more power
![]() Enthusiast ![]() ![]() Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) ![]() |
alot of people with the t3/t4 on 3ste and 5sfe say it takes a pretty long while to spool up...ur gonna have less power lower rpms and its gonna shift power up to 3-5....and ur not gonna spool up to full boost at 1300rpms anymore.....is there anyway to twin turbo a 5sfe so you can use the small turbo and the t3 together?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(MonsterBOX @ Apr 9, 2005 - 12:05 PM) alot of people with the t3/t4 on 3ste and 5sfe say it takes a pretty long while to spool up...ur gonna have less power lower rpms and its gonna shift power up to 3-5....and ur not gonna spool up to full boost at 1300rpms anymore.....is there anyway to twin turbo a 5sfe so you can use the small turbo and the t3 together? [right][snapback]268823[/snapback][/right] twin turboing a 4cyl is needlessly complex and expensive. if you want a little better top end in 3rd, maybe consider a t28BB or something like that, im sure it will spool almost as fast or you can get some good engine management and a nice external wastegate and with skilled tuning, make a t3 or t3/t4 hybrid spool up real quick. This post has been edited by 97sccelica: Apr 9, 2005 - 4:01 PM -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
![]() Enthusiast ![]() ![]() ![]() Joined Apr 12, '04 From Nj Team 6gc Currently Offline Reputation: 0 (0%) ![]() |
go with t3
-------------------- Team 6gc 2oo5
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 23, '03 From New Orleans Currently Offline Reputation: 5 (100%) ![]() |
QUOTE(97sccelica @ Apr 9, 2005 - 3:59 PM) QUOTE(MonsterBOX @ Apr 9, 2005 - 12:05 PM) alot of people with the t3/t4 on 3ste and 5sfe say it takes a pretty long while to spool up...ur gonna have less power lower rpms and its gonna shift power up to 3-5....and ur not gonna spool up to full boost at 1300rpms anymore.....is there anyway to twin turbo a 5sfe so you can use the small turbo and the t3 together? [right][snapback]268823[/snapback][/right] twin turboing a 4cyl is needlessly complex and expensive. if you want a little better top end in 3rd, maybe consider a t28BB or something like that, im sure it will spool almost as fast or you can get some good engine management and a nice external wastegate and with skilled tuning, make a t3 or t3/t4 hybrid spool up real quick. [right][snapback]268842[/snapback][/right] listen to 97scelica, he knows his stuff |
almost all the T3 series is too small for the 5s. IMO if money wasnt an object, i'd go for a T3/To4E hybrid with a 46trim compressor and a .48a/r for the turbine.
![]() in that graph i plotted for 7 and 10 psi...good stuff, and as you turn up the boost it just gets better. i'd definetly sacrifice a little spool time for what that turbo will give ya ![]() ::EDIT::: heres a plot of a 60trim T3, just so you guys can see what im talking about, this is the largest compressor in the T3 series.: ![]() as you can see, your almost off the right side in the higher RPMS...anything smaller than a 60 trim T3 and your way off the map by 4500-5k...the exact reason your car falls on its face in the upper rpms, with ubber quick spool, your turbo is too small. This post has been edited by presure2: Apr 10, 2005 - 9:14 AM -------------------- Former Team 5SFTE pro member ;)
Lo-Fi Version | Time is now: February 21st, 2025 - 4:35 PM |
