> strange noise out of my engine
post Apr 18, 2005 - 3:43 PM
Senzay
Joined Oct 27, '04
need your help, guys,
probably, as a reason of low oil level, my engine started with makinī strange noises...it sounds like a metal piece striking against another one with high frequency!
First, I thought, that the piston hits the valves when compressing!The problem seems to be in the 4th cylinder...
Really donīt know what to do!
Does anybody know, what it needs to fix it???
Thanks in advance,
kind regards...
senzay
Replies (1 - 6)
post Apr 18, 2005 - 4:47 PM
make sure u have oil in there...and take your car to a mechaic. they should be able to tell you whats wrong just by hearing the sound. normally hight pitch metalic sounds are cause by exhaust leaks, but it could be more serious then tha.
post Apr 19, 2005 - 3:36 AM
Senzay
Joined Oct 27, '04
Iīve already been at a mechanic...they told me, that it needs to demount the whole engine block - than it would be possible to tell me something!
but, I canīt afford that big of working time, it would need to do that!
I already took down the cylinder barrier and lighted it with a probe...so, I would have been able to see the 4 valves in each cylinder and possible damages!but - there was none!
Then I started the engine and checked the compression in each cylinder with a manometre -> Same compression in each of it!
As a reason of that, I donīt think, that the piston or the piston ring are the problems!
Has anyone of you guys ever had a similar problem???
regards, senzay
post Apr 19, 2005 - 4:59 AM
Silvan
Joined May 7, '04
From Leeuwarden, Netherlands
I'd go for pistonrods / crankshaft.
post Apr 19, 2005 - 9:10 AM
toyotatech3
Joined Jul 30, '04
From colorado
probably a spun bearing
post Apr 19, 2005 - 9:38 AM
Senzay
Joined Oct 27, '04
thank you, guys!
so long, senzay
post Apr 19, 2005 - 11:02 AM
unless you can post of up a video of your noise, we really cant tell you what it is.
Lo-Fi Version Time is now: November 28th, 2024 - 5:20 PM
