Anybody know what this is?, Under reciever and air controls |
May 12, 2005 - 10:44 PM |
Enthusiast Joined Apr 22, '04 From illinois Currently Offline Reputation: 0 (0%) |
First picture
Location picture Sorry about the links, it wouldn't let me use the img link Well, the only info. I can give, is this wasn't in my 95 celica gt, so....any ideas? Thankyou 6gc -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
May 12, 2005 - 10:56 PM |
Enthusiast Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) |
ecu
May 12, 2005 - 10:58 PM |
then what's under the glove box?
May 12, 2005 - 11:03 PM |
Enthusiast Joined Nov 3, '04 From Colorado Currently Offline Reputation: 0 (0%) |
The thing in the picture is the stock amp.
The ECU is actually deeper than that. This post has been edited by Newbie: May 12, 2005 - 11:03 PM |
May 12, 2005 - 11:09 PM |
Stock amp, that's what i was half-way afraid of. So what's going to happen when my aftermarket reciever get's here?
May 12, 2005 - 11:36 PM |
lol, yeah its the amp, not the ecu
May 13, 2005 - 12:09 AM |
Enthusiast Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
Unplug the car harness from that amp and connect it to the adaptor harness that you should have got with the new unit, there should be a short harness section from that old amp to the current head unit you wont need anymore .
May 13, 2005 - 8:50 AM |
So you're saying i need to completely unplug the amp?
May 13, 2005 - 9:05 AM |
Enthusiast Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) |
Screw the stock amp! You won't need it anymore. I completely removed mine and put my alarm there.
May 13, 2005 - 9:26 AM |
Enthusiast Joined Jan 28, '05 From Cincinnati, Ohio Currently Offline Reputation: 0 (0%) |
I had the same problem my man. Let me tell ya, it is HARD to get to those wires, unless you remove the whole amp alltogether. I had to reach all the way under the amp, grab the wires and unplug them. I used the how-to guide...it really helps.
This post has been edited by red94celicagt: May 13, 2005 - 9:27 AM -------------------- Speeding is only Illegal...
If you Get Caught |
May 13, 2005 - 2:08 PM |
The harness that i bought has plugs that plug into your stock plugs. So, no wire cutting. Basically, that means i can still use that amp. Then the other end of that harness has the open wires for the aftermarket reciever. harness
[SIZE=14]Scratch this post This post has been edited by spunky393: May 13, 2005 - 6:20 PM -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
May 13, 2005 - 6:18 PM |
QUOTE(97GTinKC @ May 13, 2005 - 12:09 AM) Unplug the car harness from that amp and connect it to the adaptor harness that you should have got with the new unit, there should be a short harness section from that old amp to the current head unit you wont need anymore . [right][snapback]286334[/snapback][/right] This is complete utter bull-crap. After more research and careful evaluation, what I have is Toyota's "Premium Sound." So, on the back, there is only one plug. I went back to my audio store in town, and told them i have a stock amp. They knew exactly what i was talking about, gave me a special plug in exchange for the old double plugs, and he said that's it. It has your basic, turn on wire for the stock and any other amp. it has 4 rca's input and output. Ground, Battery/Memory, Ignition/Accy, Power Antenna, and Amplifier Turn on. If you would like a picture, i would be glad to provide that. -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
May 13, 2005 - 6:44 PM |
hmm would that mean you can hook up you Ipod to the stock sound system?
May 13, 2005 - 10:37 PM |
Enthusiast Joined Dec 1, '02 From Pittsburgh, PA Currently Offline Reputation: 0 (0%) |
QUOTE(spunky393 @ May 13, 2005 - 4:18 PM) QUOTE(97GTinKC @ May 13, 2005 - 12:09 AM) Unplug the car harness from that amp and connect it to the adaptor harness that you should have got with the new unit, there should be a short harness section from that old amp to the current head unit you wont need anymore . [right][snapback]286334[/snapback][/right] This is complete utter bull-crap. After more research and careful evaluation, what I have is Toyota's "Premium Sound." So, on the back, there is only one plug. I went back to my audio store in town, and told them i have a stock amp. They knew exactly what i was talking about, gave me a special plug in exchange for the old double plugs, and he said that's it. It has your basic, turn on wire for the stock and any other amp. it has 4 rca's input and output. Ground, Battery/Memory, Ignition/Accy, Power Antenna, and Amplifier Turn on. If you would like a picture, i would be glad to provide that. [right][snapback]286654[/snapback][/right] No it's NOT bullcrap! He's right on. The "premium sound" system is the stereo with the separate factory amp. The amp has one plug going into it(from the receiver) and one plug coming out of it BUT splits into TWO plugs that go into the factory wiring. In order to use the factory wiring with an aftermarket HU you MUST do 1 of 2 things: a) plug into the 2 blue factory plugs or b) find an adaptor that plugs into the 1 plug coming OUT of the amp. I found it easier and cheaper to do "a" but I believe they do make adaptors to do "b". Either way, you have to bypass the amp or the signal will get amplified twice - and no, that's not a good thing. |
May 13, 2005 - 10:59 PM |
QUOTE(runriot95 @ May 13, 2005 - 10:37 PM) QUOTE(spunky393 @ May 13, 2005 - 4:18 PM) QUOTE(97GTinKC @ May 13, 2005 - 12:09 AM) Unplug the car harness from that amp and connect it to the adaptor harness that you should have got with the new unit, there should be a short harness section from that old amp to the current head unit you wont need anymore . [right][snapback]286334[/snapback][/right] This is complete utter bull-crap. After more research and careful evaluation, what I have is Toyota's "Premium Sound." So, on the back, there is only one plug. I went back to my audio store in town, and told them i have a stock amp. They knew exactly what i was talking about, gave me a special plug in exchange for the old double plugs, and he said that's it. It has your basic, turn on wire for the stock and any other amp. it has 4 rca's input and output. Ground, Battery/Memory, Ignition/Accy, Power Antenna, and Amplifier Turn on. If you would like a picture, i would be glad to provide that. [right][snapback]286654[/snapback][/right] No it's NOT bullcrap! He's right on. The "premium sound" system is the stereo with the separate factory amp. The amp has one plug going into it(from the receiver) and one plug coming out of it BUT splits into TWO plugs that go into the factory wiring. In order to use the factory wiring with an aftermarket HU you MUST do 1 of 2 things: a) plug into the 2 blue factory plugs or b) find an adaptor that plugs into the 1 plug coming OUT of the amp. I found it easier and cheaper to do "a" but I believe they do make adaptors to do "b". Either way, you have to bypass the amp or the signal will get amplified twice - and no, that's not a good thing. [right][snapback]286733[/snapback][/right] This AF harness is made to connect between the reciever and the IN harness. So, it'll go: Reciever, After Market harness, Stock Harness IN, Stock Amp, Stock Harness OUT -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
May 13, 2005 - 11:05 PM |
Enthusiast Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) |
ITS DEF UR ecu
May 13, 2005 - 11:21 PM |
QUOTE(StreetRacing10PSI @ May 13, 2005 - 11:05 PM) ITS DEF UR ecu [right][snapback]286742[/snapback][/right] This is why people leave 6gc.net, because of stupid A** comments like this. -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
May 13, 2005 - 11:22 PM |
May 14, 2005 - 5:51 PM |
So, you're using the receiver's pre-outs then? I assumed that you didn't want to use the factory amp, my mistake.
I don't know how good the factory amp is, but I think I'd rather use the head unit's built-in amp or an aftermarket amp instead. |
May 14, 2005 - 8:34 PM |
QUOTE(runriot95 @ May 14, 2005 - 5:51 PM) So, you're using the receiver's pre-outs then? I assumed that you didn't want to use the factory amp, my mistake. I don't know how good the factory amp is, but I think I'd rather use the head unit's built-in amp or an aftermarket amp instead. [right][snapback]287013[/snapback][/right] Well, if you think about it, the stock reciever probably puts out 50x4 watts plus the amp to run the premium speakers. So, if my new reciever is putting out 54X4 watts, then i should still use that stock amp. Especially if there is a aftermarket harness to get everything you can out of the amp. -------------------- The most important lesson I learned from Karate-Dō Kyōshan – “You can not be what you do not believe you are” |
Lo-Fi Version | Time is now: December 4th, 2024 - 1:32 PM |
