95 ST 7A-FE burning oil, problem? |
May 18, 2005 - 2:40 AM |
Enthusiast Joined Mar 19, '05 From Seattle Washington Currently Offline Reputation: 0 (0%) |
hmm... well basically I have to go to Jiffy lub and top off my oil every now and then. The oil light comes on after 1500 miles or so. I think it is just burning oil since there is no visible leakage. Anybody having the same problem? I use a high grade synthetic.
May 18, 2005 - 4:30 AM |
if your car burn oil, then your exhaust will have a blue-ish color to it.
May 20, 2005 - 3:03 AM |
Enthusiast Joined Feb 27, '04 From Illinois Currently Offline Reputation: 1 (100%) |
Yep...I burn oil like theres no tomorrow....I hate it. I use 10W-40. Has anyone tried those concoctions that you add to your oil that is supposed to stop oil consumption? what are your reactions to it?
May 20, 2005 - 11:47 PM |
Enthusiast Joined Mar 31, '03 From BC Currently Offline Reputation: 0 (0%) |
94 ST with 125,000 miles. Burns less than 1 quart per 3000 miles. Used 1 can of engine restorer twice and seemed to help.
Restorer |
May 21, 2005 - 1:01 AM |
Enthusiast Joined Apr 1, '05 Currently Offline Reputation: 0 (0%) |
94 st with 155,000 miles burns prob under half a quart every 3000 miles
-------------------- http://www.infectwow.com : launching 04.01.2007
May 21, 2005 - 1:46 PM |
Enthusiast Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
Man u've to look at the reality....IF you're lucky (but once seen the amount of oil consuption I don't think u are ) it could be the valves stems seals...
Anyway at 99% your rings are finally gone after all those miles and it's time to replace them. In a high milleage engine I think it won't be possible to replace just rings cuz of the cylinders ovalization, but the machine shop will value that. If not possible you need to get cylinders bored to at least 82mm (stock is 81mm) and replace pistons with oversized set with rings.... Anyway since the engine will be opened u can always make some "works" Good luck |
May 21, 2005 - 11:17 PM |
my car has only 103,000 miles on it.
May 22, 2005 - 11:17 AM |
there's no a fixed milleage to have trouble man...I had to do it at 70k miles....
May 22, 2005 - 2:20 PM |
Enthusiast Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
Yea mine burns oil bad if I go above a like 3500 rpm. That is why I'm working on a 3sgte.
May 23, 2005 - 9:26 AM |
Enthusiast Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
My 94 ST with 167k uses alot of oil. No smoke or leakage. Piston rings are shot i guess. Oil is cheap! 94cents for a qrt of Supertech from walmart. I just keep extra oil and add whenever i need it Shoot i drive the car back and forth to florida from ohio and i add about a qrt each way Car gets like 36-40mpg on the highway and gets me where i need to go everyday.
May 23, 2005 - 10:23 AM |
lucky i have been using synthetic and then it started burning oil like a whore
so 94cents i wish try like 1.50$ or sumthing random like that |
May 23, 2005 - 11:38 AM |
you will have more loss with synthetic for it will slip past the rings and seals much easier.
Lo-Fi Version | Time is now: November 24th, 2024 - 9:40 AM |
