> High RPM on 5th Gear
post May 20, 2005 - 9:23 PM
eyohannie
Joined May 20, '05
From San Diego, California
I'm pretty much new to driving stick (learned a week ago), but something seems wrong when I'm crusing on the freeway on 5th gear. Is it normal for me to be getting around 3,000-3,200 RPM going around 60-65 mph? It just seems a little high compared to my now-scrapped automatic eclipse which got around mid 2,000's at those speeds.
Replies (1 - 19)
post May 20, 2005 - 10:13 PM
CupCrazy38
Joined Jul 11, '03
From Kennesaw, Ga
Don't know about the GT, but it's the same way for my ST.
Now I'm loving my new 6 speed RSX-S smile.gif Still around 3K rpm around 60 mph...but I've got a higher redline now smile.gif
post May 20, 2005 - 10:19 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
Its just that way celicas are. I never need to touch 4k in my civic.
DEF
I will return one day.
post May 20, 2005 - 11:56 PM
tomazws
Joined Oct 30, '04
From So Cal
For me, 3700~ doing 80MPH.
post May 21, 2005 - 3:17 AM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
hmm, 80 mph on my auto ST is like 3200 rpm.
post May 21, 2005 - 5:32 AM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
GT for me = 4k is 80mph. i think 3k is 60 ish i dont do 60... ish often... so i dont know smile.gif
post May 21, 2005 - 11:38 AM
eyohannie
Joined May 20, '05
Well the thing is, usually autos have a lower RPM for higher speeds compared to stick, and since I have to drive on the freeway a lot, I'm worried that consistent 3k+ RPM will reduce gas mileage and/or cause increased engine wear.
post May 21, 2005 - 3:16 PM
mikew04
Joined Feb 19, '04
From austin tx
I wouldnt worry about it, i get 28mpg on highway trips going 90 or above.
post May 22, 2005 - 12:29 AM
red94celicagt
Joined Jan 28, '05
From Cincinnati, Ohio
manual trannys are made to handle 3k RPM at 65 MPH just as auto trannys are programmed to go about 2,4k RPM at 60...
Your car will be fine...gas milage will be same if not better than auto...you will not burn out engine internals or tranny...
Basically...keep the RPMs out of th redline range...your car will be fine as it was made to operate safely and reliably at any RPM up to about 6k
Speeding is only Illegal...
If you Get Caught
post May 26, 2005 - 12:14 AM
MonsterBOX
Joined Jan 8, '05
From Alabama
hahaha they wont go to the redline range stupid fuel shutoff
post May 26, 2005 - 1:34 AM
macavely
Joined Nov 4, '02
wow i'm still in 4th grear when doing 60 ... us ally don't shift into 6th till i hit about 75- 80mph ... but i drive every agressive ... in the city i never get out of 3rd grear...
post May 26, 2005 - 8:15 AM
red94celicagt
Joined Jan 28, '05
QUOTE(macavely @ May 26, 2005 - 1:34 AM)
[right][snapback]291952[/snapback][/right]
well yea...in fourth you could actually get up to about 100 in fourth...it says the max speed per gear in the owner's manual and I believe the highest in fourth is about 100. thats relining it, tho...probably even going into redline a bit (6,5 or 7k)
If you Get Caught
post May 26, 2005 - 8:37 AM
MAC since when do we have 6 gears?!
post May 27, 2005 - 5:06 PM
shin
Joined Aug 21, '04
From New York City
hmm i think it's normal for the celi to reach 3000+ rpm when at 60.. lol... but i'm not like mac.. when i'm on local.. i shift at low rpms so to prevent my muffler from being to loud. when i'm at highways i normally shift at around 4000rpm.
~*MuH NeW RiDe*~
post May 28, 2005 - 6:53 PM
80 MPH for me is around 4,300 - 4,400 RPM. The AE101 C-52 has shorter gears than the AT200 C-52.
post Sep 21, 2005 - 11:19 PM
Celicav
From Virginia
Well, now that I currently own both an Auto and Manual 1995 GT Celicas, here are my observations:
GT Auto at 80 mph ~ 3,100 RPM
GT Manual at 80 mph - almost 4,000 RPM
So, there is nothing to worry about here with the manaul? Someone explain this. Thanks.
post Sep 22, 2005 - 2:29 AM
94ST2
Joined Feb 7, '05
From Fresno, CA
QUOTE(MonsterBOX @ May 26, 2005 - 12:14 AM)
[right][snapback]291932[/snapback][/right]
The redline starts at 6200 and my fuel cutoff is at 6500-6800 somewhere around there its been awhile since I tested it out.
post Sep 22, 2005 - 12:02 PM
QUOTE(Celicav @ Sep 21, 2005 - 11:19 PM)
[right][snapback]337187[/snapback][/right]
no thats normal. manuals and autos are geared differently.
post Sep 23, 2005 - 11:31 AM
blu94gt
Joined Mar 23, '05
From Kansas City
yeah, definitely nothing to worry about. The auto and manual are geared differently because the auto is technically only a 4 speed.
1999 Celica GT
post Sep 24, 2005 - 2:39 AM
king_wsk
Joined Mar 17, '05
From Northridge, CA
if you want to get the most performance, shift around 5,300~5,400 rpm as the high rpms don't provide as much power. my 94' GT is my first stick as well... and learning to drive stick on it has been a dream. You'll stall a few times, but you'll get the hang of it after a week or so.
And don't worry about the high end... i mean there is no point in going very high as it doesn't provide as much power as the power band (4k-5.3k), but i've had my car at 6.8k for a few sec and it was just fine.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:59 PM
