> Q about wiring, directly from battery or cig lighter?
post May 26, 2005 - 10:00 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
I was wondering if there was a power difference from the battery and say the cigarette lighter? If i took a 12v light that was wired to the cig lighter and hooked it up directly to the batt, would that make a difference? It just seems to me that a lil 12v bulb would explode if i hooked it up to the terminals of a car batt. Is there a difference in amps? could i light a 74 bulb straight from the battery?
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
Replies (1 - 2)
post May 26, 2005 - 10:25 PM
yes. there is really no difference. I'm sure you will find lots of members that use the lighter for power for neons, swiches, ect. If you are worried about a voltage drop or surge either use a relay or an inline fuse for saftey.
post May 27, 2005 - 4:23 AM
Hanyo
Joined Aug 16, '03
From Bay area
the thing you have to worry about is the gauge of the lighter wire.
Its not a very thick wire; So if you pull too much current through it, the wire might melt.
Lo-Fi Version Time is now: February 26th, 2025 - 1:38 PM
