Enthusiast ![]() Joined Mar 28, '05 From California Currently Offline Reputation: 0 (0%) ![]() |
yesterday i wanted to run my wiring through the harness hole that is near the battery. the stock harness is runs near the battery, in the fender and then into the interior. i remove the 3 bolts on the top, the nuts that connect the bump and fender. the bolt near the door, the other bolt in the inner fender near the door, and the two under near the front side skirt. then remove the fender mud lining. i tried too pull it off but i couldnt do it like it was still stuck ??? any suggestions?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
3 bolts on top inside the engine bay
1 bolt inside the door 1 bolt inside the fender near the door 3 bolts inside the fender that connect front bumper 2 bolts under headlight 2 bolts under car how to- remove front bumper - remove bolts inside engine bay going across bar (4) - remove bolts holding plastic to bottom of bumper (?) - remove bolts that connect bumper to fender (3 per side) remove low beam - two on top one on bottom (3 per light) remove fender - remove bolts from under headlight (2) - remove bolts inside engine bay (3) - remove bolt inside door (1) - remove bolts inside fender (1) - remove bolts undercar (2) This post has been edited by playr158: Jun 2, 2005 - 2:56 PM |
thanks
Enthusiast ![]() Joined Dec 18, '11 From Honolulu, HI Currently Offline Reputation: 3 (100%) ![]() |
3 bolts on top inside the engine bay 1 bolt inside the door 1 bolt inside the fender near the door 3 bolts inside the fender that connect front bumper 2 bolts under headlight 2 bolts under car how to- remove front bumper - remove bolts inside engine bay going across bar (4) - remove bolts holding plastic to bottom of bumper (?) - remove bolts that connect bumper to fender (3 per side) remove low beam - two on top one on bottom (3 per light) remove fender - remove bolts from under headlight (2) - remove bolts inside engine bay (3) - remove bolt inside door (1) - remove bolts inside fender (1) - remove bolts undercar (2) are all these bolts 10mm? |
more than likely its been like 9 or 10 years since i did it last
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) ![]() |
3 bolts on top inside the engine bay 1 bolt inside the door 1 bolt inside the fender near the door 3 bolts inside the fender that connect front bumper 2 bolts under headlight 2 bolts under car how to- remove front bumper - remove bolts inside engine bay going across bar (4) - remove bolts holding plastic to bottom of bumper (?) - remove bolts that connect bumper to fender (3 per side) remove low beam - two on top one on bottom (3 per light) remove fender - remove bolts from under headlight (2) - remove bolts inside engine bay (3) - remove bolt inside door (1) - remove bolts inside fender (1) - remove bolts undercar (2) are all these bolts 10mm? Some of them are. -------------------- God made man....
Everything else... Made in China ![]() |
Enthusiast ![]() ![]() Joined Jul 1, '14 From Hawaii Currently Offline Reputation: 3 (100%) ![]() |
3 bolts on top inside the engine bay 1 bolt inside the door 1 bolt inside the fender near the door 3 bolts inside the fender that connect front bumper 2 bolts under headlight 2 bolts under car how to- remove front bumper - remove bolts inside engine bay going across bar (4) - remove bolts holding plastic to bottom of bumper (?) - remove bolts that connect bumper to fender (3 per side) remove low beam - two on top one on bottom (3 per light) remove fender - remove bolts from under headlight (2) - remove bolts inside engine bay (3) - remove bolt inside door (1) - remove bolts inside fender (1) - remove bolts undercar (2) are all these bolts 10mm? Some of them are. All of them should be 10mm, i just checked since i had my front bumper off. This post has been edited by Noahwhite2014: Dec 7, 2014 - 5:56 AM |
Lo-Fi Version | Time is now: February 22nd, 2025 - 1:11 AM |
