> 89 gts rear brakes, will they work/
post Jul 13, 2005 - 5:28 PM
25thcelica
Joined Oct 11, '04
From Silver Spring Maryland
i found a near perfect 89 gts in the junk yard and it has rear disc brakes. the are 5x100 and I was just wondering if I could use these to do a swap on my 6 gen.
Thanks in advance
Fernando
Replies (1 - 10)
post Jul 13, 2005 - 6:47 PM
FallenHero
Joined Dec 26, '02
From Alabama
if that's 5th gen, then yes. I used 92 GTS rear disks on mine and they're hardcore.
post Jul 13, 2005 - 7:07 PM
25thcelica
Joined Oct 11, '04
nope it was a forth gen but they look like they would work just don't want to buy them if I don't know more info
post Jul 13, 2005 - 8:00 PM
FallenHero
Joined Dec 26, '02
From Alabama
Well, i just bolted the whole housing onto my car. Take a look at it, do some measurements, and see if it'll fit.
post Jul 13, 2005 - 8:41 PM
25thcelica
Joined Oct 11, '04
I will do that cause they seem to be the same size and I believe they look like the same parts hell why not I will try it if it works then that will give us another soruce for rer disc brakes
post Jul 14, 2005 - 6:00 AM
Hanyo
Joined Aug 16, '03
From Bay area
sweet, test them out and report back with us. I see a bunch of older celica's in the junk yard. Maybe we can use the 5 lug 4th gen rear disk's
post Jul 14, 2005 - 4:25 PM
25thcelica
Joined Oct 11, '04
QUOTE(Hanyo @ Jul 14, 2005 - 11:00 AM)
[right][snapback]312252[/snapback][/right]
will do I will go this sat to get them and report later that day so until then keep hope alive
post Jul 14, 2005 - 5:49 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
They should work just fine. I'm about 90% sure they'll bolt right up... the only issue might be the e-brake cables. I know that the calipers are 99% the same between 4th 5th and 6th gens. The 4th gens have a slightly different caliper bracket... but it's still technically the same thing.
post Jul 15, 2005 - 6:05 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
In all likelyhood with a shared 5/100 hub setup, you could swap the backing plate (which holds the caliper bracket and e-brake assembly) using your current hub. Rotor would definately fit onto your existing hub, though I don't know about how your wheels would appreciate the new configuration.
Also consider swapping the rear proportioning valve.
post Jul 15, 2005 - 12:44 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE(Galcobar @ Jul 15, 2005 - 11:05 AM)
[right][snapback]312615[/snapback][/right]
I read somewhere the proportioning valves are the same. The difference is the brake lines, in which the drums used metal lines and the discs used rubber. Also, I don't reccomend getting the assembly in "parts". It'll just cause a massive headache. Be sure to get the entire spindle complete. Don't buy it in parts.
post Jul 15, 2005 - 12:58 PM
FallenHero
Joined Dec 26, '02
From Alabama
QUOTE(Kwanza26 @ Jul 15, 2005 - 10:44 AM)
[right][snapback]312747[/snapback][/right]
Agreed. I used the entire housing on mine. And like they said, get the e-brake cables and the regular brake lines.
Lo-Fi Version Time is now: April 23rd, 2025 - 2:35 PM
