> clicking sound, rear left
post Jul 24, 2005 - 10:07 PM
soven
Joined Mar 14, '05
From Auckland,New Zealand
My passengers are telling me that there is a constant ticking noise coming from the rear left of my car.
It is not noticeable to me and only the back passengers could hear it. it is just a clicking sound that speeds up when i travel faster.
Any idea what it could be?
Replies (1 - 8)
post Jul 24, 2005 - 10:13 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
OMG! The same thing happens to me! Except for me, it's on the back passenger side. I can hear it. It sounds like the wheel or something. I don't know what it could be. It usually happens when I run the engine hard. Kinda scary.
post Jul 24, 2005 - 10:26 PM
Cutrara
Joined May 6, '05
From PA
Stones in the tire treads? Thats what I get after I drive over fine gravel roads.
post Jul 25, 2005 - 2:52 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Check:
Wheel bearings (lift the car and wobble the wheel)...
Rear links bushings
struts/shocks
tires
jack
post Jul 26, 2005 - 12:23 AM
soven
Joined Mar 14, '05
QUOTE(Kwanza26 @ Jul 26, 2005 - 7:52 AM)
Check:
Rear links bushings
struts/shocks
tires
jack
[right][snapback]316655[/snapback][/right]
Will check wheel bearings and rear link bushings(how to check this?).
Struts/shocks do not squeak or anything except in themorning. tyres are new. Checked the jack.
post Jul 26, 2005 - 1:23 AM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Hmmm...I've had this same problem for a while in my car. Don't really consider it a real problem per se, just something that i'll fix eventually. I'll have to check it out, glad to hear that somebody else but me has it too though.
post Jul 26, 2005 - 7:04 AM
ejanuary
Joined Jul 26, '05
This sound emanates from the strut assembly that is worn out
Jack the wheel and move it up and down vigorously you maybe able to simulate thenoise. As for checking wheel bearings with the hand brake offafter jacking hold the wheel on two opposite sides and try shaking left right if they are wornout a knocking sound will be heard
QUOTE(soven @ Jul 25, 2005 - 5:07 AM)
[right][snapback]316377[/snapback][/right]
post Jul 26, 2005 - 11:18 AM
gtcelica94
Joined Apr 4, '04
i have this same problem
post Jul 26, 2005 - 8:51 PM
Celica_Kid95st
Joined Feb 24, '05
From Pittsburgh, PA
How can i tell if my strut is bad. Cause i have kinda the same problem with back driver side. Wierd noise. Thanks -john
Lo-Fi Version Time is now: November 23rd, 2024 - 9:30 PM
