> new interior gauge pic, LEDs
post Aug 11, 2005 - 11:03 PM
just trying something new...something blue
Replies (1 - 18)
post Aug 11, 2005 - 11:21 PM
Silver94CelicaOw...
Joined Oct 13, '02
From Blairstown, New Jersey
Very nice work Dustin. BTW.....is that a boost gauge I see to the left?? Fill me in.
Is it just the pic or are some areas brighter than others? When I put LEDs in my cluster parts were bright while other parts were dark and it didn't look so good.
post Aug 11, 2005 - 11:30 PM
when I resized the pic with MS paint it did distort it a bit. There are some areas that are brighter than others, getting the right LEDs are the key. Here is a more accurate pic
post Aug 11, 2005 - 11:38 PM
Cutrara
Joined May 6, '05
From PA
Looks awesome, this is 194 led right? I think I might do mine in white like the new Toyotas
post Aug 12, 2005 - 12:50 AM
gald the leds worked out for u ... did u go with the 6led 194 bulb for the oil gauge, or the 9 led one?
post Aug 12, 2005 - 7:30 AM
actually I used the 6. The size of the 9 I don't think would of fit through the hole in the back of the cluster wink.gif
post Aug 12, 2005 - 9:13 AM
WannabeGT4
Joined Oct 10, '03
From Wichita, KS
Looks pretty good. I especialy like the look of the single gauge.
As far as replacement bulbs go the standard diameter of any 194 should not be more than 15 millimeters. All you should have to worry about is the length.
"SUPER REFRACTOR" a.k.a. "matrix" 5 LED bulb will give you 100% even light distribution. That is what I bought and I am completely satisfied with the outcome. No "hot spots" at all.
post Aug 12, 2005 - 12:26 PM
Thats B.A.
post Aug 12, 2005 - 10:57 PM
slipgun
Joined Jun 2, '03
From Annandale VA
Looks good man, I got thoes wide angle led's and they did the same thing to me. I got a new set though that have the wide angle with like 4 led's pointing sideways on it, pretty expensive but check em out if the uneaven lighting bothers you. I imagine mine are like wanabegt4's user posted image
This post has been edited by slipgun: Aug 12, 2005 - 10:59 PM
post Aug 13, 2005 - 8:57 AM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
last pic looks good
post Aug 13, 2005 - 11:26 PM
Jaws4God
Joined Mar 27, '04
mine are brighter and darker in places too... The speedometer is the brightest.. the fuel and temp are a little dimmer.. and the tach is almost not lit frown.gif
post Aug 14, 2005 - 2:19 AM
rocky2006
Joined Aug 18, '04
From St. Louis, Missouri
batman, what did you use for the blinkers?
post Aug 14, 2005 - 11:43 PM
QUOTE(rocky2006 @ Aug 14, 2005 - 2:19 AM)
[right][snapback]323936[/snapback][/right]
I used blue LEDs from ebay (bulb #74)
First I replaced the green directional covers with clear ones then replaced the bulbs with the blue LED bulbs. I was thinking about changing the blue turn bulbs to amber or yellow ones instead for a better contrast. opinions ...?
post Aug 15, 2005 - 1:18 AM
rocky2006
Joined Aug 18, '04
i think they look grat as-is. i put in blue tinting over blue plastic (took out stock green plastic blinkers) for my blinkers and they turned out a tealish. what is the link to the LED's you bought?
post Aug 15, 2005 - 2:27 AM
for the directionals, ebay item # 7992960540
I first tried the blue lighting stuff that is over my clock but they were more purple than blue. Then I tried replacing the green covers I used part of a plastic milk/water gallon jug (near the handle of the jug). I wanted to find something with the same texture of the green covers and the jug was perfect. I needed something that wasn't clear, but was see through and frosted/white.
I put 2 jug peices on each side and the LEDs in and it is wicked bright and blue.
post Aug 23, 2005 - 9:54 PM
SSJChar
Joined Aug 22, '05
From Saskatoon, SK
I just purchased an st204, and the dash lights are way too dim for me, even when cranked to max. how do LEDs work? i don't want to know how they work technically, but do you just plug them into the existing bulb sockets? is any capacitor soldering going to have to be done?
post Aug 24, 2005 - 12:28 AM
Cutrara
Joined May 6, '05
From PA
You can buy type 194 LEDs that will fit into the existing sockets.
post Aug 24, 2005 - 1:20 AM
blu94gt
Joined Mar 23, '05
From Kansas City
i just put blue matrix LEDs in my gauges the other day, they look great! pics to come
1999 Celica GT
Lo-Fi Version Time is now: January 11th, 2025 - 10:35 AM
