what does it mean when a person says: "the engine is hydro locked or just plain ol siezed?"??? what does this mean? does this mean the engine is bad? can it be fixed? thanks
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 14, '03 From Jacksonville, FL Currently Offline Reputation: 2 (100%) ![]() |
Yes, it means the engine is bad. The only way around it is a rebuild or a new engine.
Correct me if I'm wrong. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Jul 19, '04 From Los Angeles, CA Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(Jen @ Aug 17, 2005 - 12:48 AM) Yes, it means the engine is bad. The only way around it is a rebuild or a new engine. Correct me if I'm wrong. [right][snapback]324926[/snapback][/right] Yeah thats bad, jen is right. |
so i could drop in a 5sfe motor and it would be fine?
QUOTE(mon3y19 @ Aug 17, 2005 - 1:51 AM) so i could drop in a 5sfe motor and it would be fine? [right][snapback]324943[/snapback][/right] If you have a GT then yes. But why drop a 5sfe in when you could do a 3sgte swap? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(CheesyLobster @ Aug 17, 2005 - 4:01 AM) QUOTE(mon3y19 @ Aug 17, 2005 - 1:51 AM) so i could drop in a 5sfe motor and it would be fine? [right][snapback]324943[/snapback][/right] If you have a GT then yes. But why drop a 5sfe in when you could do a 3sgte swap? [right][snapback]325048[/snapback][/right] Time. Money. Practicality. Reliability. Labor. -------------------- |
![]() Enthusiast ![]() ![]() ![]() Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) ![]() |
If you want to swap to a beams or 3sgte, you may as well do it now. NO point in doing 2 swaps.
-------------------- AIM : FAQdaWorld
QUOTE(FAQdaWorld @ Aug 18, 2005 - 6:31 AM) If you want to swap to a beams or 3sgte, you may as well do it now. NO point in doing 2 swaps. [right][snapback]325414[/snapback][/right] that would be my stand, too. |
To make things easier, I would just put in a new low mileage 5sfe, and turbo it. Or do what I did and rebuild then turbo.
Enthusiast ![]() ![]() ![]() ![]() Joined Jul 10, '03 From Appleton,WI Currently Offline Reputation: 0 (0%) ![]() |
QUOTE Or do what I did and rebuild then turbo. I believe Jen is hinting something at us! -------------------- ![]() A Jaws4God Creation... |
Lo-Fi Version | Time is now: February 25th, 2025 - 12:45 PM |
