![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 19, '04 From Scottsdale, Az Currently Offline Reputation: 2 (100%) ![]() |
Updated and edited post:
Ok, I just retested my plugs, and i am only recieveing spark on cylinder 3. Any suggestions? This post has been edited by madmods: Aug 22, 2005 - 10:41 AM |
you got the right idea. you just use your normal spark plugs... if you get spark off of one, then youll get it off the other 4.
edit: might want to pull the efi fuse too, and unplug all 4 plug wires too This post has been edited by lagos: Aug 21, 2005 - 2:50 AM -------------------- 15PSI - 30MPG - Megasquirt Tuned
QUOTE(madmods @ Aug 21, 2005 - 2:46 AM) Updated and edited post: Ok, I have no spark. What do i do next? [right][snapback]326481[/snapback][/right] no spark at a plug ? trace it back through the wire, the cap, ect. Find out where you are losing it. -------------------- |
yeah like batman said.... next you want to test the king lead plug wire that comes off from your coil... just be very carefull cause it can shock the **** out of you. if you get spark there, then the problem is with the distributor, the cap or the rotor. if you dont get spark, then the problem is with the coil, or igitor...or maybe a blown fuse somwhere.
![]() Enthusiast ![]() ![]() ![]() Joined Oct 10, '04 From New Jersey Currently Offline Reputation: 0 (0%) ![]() |
i had the same problem and it ended up that a wire to my coil pack came loose.
bad spark plug wire, bad cap and rotor or bad distributor.
QUOTE(lagos @ Aug 21, 2005 - 8:37 PM) bad spark plug wire, bad cap and rotor or bad distributor. [right][snapback]326598[/snapback][/right] Alright, the wires are good, the cap is suspect. |
check your cap and rotor...those are cheap..
![]() -------------------- Former Team 5SFTE pro member ;)
QUOTE(presure2 @ Aug 21, 2005 - 11:03 PM) check your cap and rotor...those are cheap.. ![]() [right][snapback]326627[/snapback][/right] just bought a rotor for 5 and a cap for 12. Hopefully this solves the problem. Thanks for the help guys |
Im still stranded, and only getting spark out of 1 cylinder. A new cap and rotor didn't do a thing. A check into my coil showed that I was getting a proper reading to the resistance of the secondary coil, but 0 resistance to the primary coil. The manual says replace it. I'm going to have to buy one
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
ouch your coil or distributor.....expensive
Lo-Fi Version | Time is now: February 22nd, 2025 - 7:00 AM |
