![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) ![]() |
Hey, I was wondering which electronic is good for my car. Should I get an Piggyback system like Megasquirt, or should I get an Engine managment system?
I need something that is affordable, reliable, and fast. Some things im looking for is the programability of using a Laptop and the need for less hardware to buy (eg. sensors, new parts that have to be wield on, or take engine apart just to put it on). Any suggestions? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 22, '03 From NOVA Currently Offline Reputation: 16 (100%) ![]() |
if you have a stock ST you don't need anything more then a SAFC 2
if you have a crazy turbo kit and such a full stand alone is wise....i've been lookin at prs4 |
Its not really stock anymore, I swapped it out with a 4age ST and my ECU was partially fried. It will start up, but it has super terrible A/F mixture (Actually Fire is spitting out of that thing!) and wont even go a feet or 2.
please say you are using a 4age ecu.......
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 30, '02 From Washington Spokane / Coeur D' Alene Idaho Currently Offline Reputation: 11 (100%) ![]() |
im using the sds system go check it out
QUOTE(nik @ Aug 23, 2005 - 9:51 AM) im using the sds system go check it out [right][snapback]327195[/snapback][/right] I heard SDS is good too, but you have to buy a few parts to attach to the engine just make the thing work and I really dont want to mess around with installing mechnical parts to the engine right now, because I dont have time. |
" because I dont have time" that phrase and standalone is an oximoron
you HAVE to have time to do a stand alone it takes a very good time of programing and tunning on a dyno and splicing wires and such..... |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) ![]() |
emanage wont work too well if your ECU is fried, nor will any piggyback system
SDS runs off of a hall sensor, which requires a custom braket that holds the sensor near the crank pully and then for a 4cyl drilling 3 holes in the pulley for magnets. its a good amount of work, but its not that hard megasquirt is good, you can probably have a complete setup for $400. the sensors are cheap, or you can get them at a junkyard, i actually have 4 sets of IAT's and CHT's that are used in MS setups wiring the SDS is much easier, you tell them when you order, what engien you have, and they make a harness with megasquirt, you have to make the harness either way, if you dont have time, go buy a replacement 4age ECU. i have personal experience with both SDS and MSnS. they take time to setup and get running properly -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Michigan Currently Offline Reputation: 0 (0%) ![]() |
take it to a shop and have them install a hydra-nemesis unit and tune it
-------------------- ![]() Believer, you'll leave her, in leaving them all No but I don't buy it Like anything you do, as anyone you are Cause I'm... Ten Speed, of God's Blood & Burial |
QUOTE(boosted_K2 @ Aug 23, 2005 - 8:11 AM) take it to a shop and have them install a hydra-nemesis unit and tune it [right][snapback]327223[/snapback][/right] funny, i want to get a hydra ems for my WRX sooooo many features sadly, i need a tranny first -------------------- 1994 Celica GT4 WRC Edition
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) ![]() |
QUOTE(playr158 @ Aug 23, 2005 - 12:12 AM) if you have a stock ST you don't need anything more then a SAFC 2 [right][snapback]327107[/snapback][/right] I don't mean to hijack the thread or anything, I was just wondering what kind of gains you can get from a SAFC 2. -------------------- |
not much in gains....but you might get 1 or 2.....the idea is to change your air fuel
to run stoich.... |
Lo-Fi Version | Time is now: February 22nd, 2025 - 6:09 PM |
