> need to know what parts in need for this, shifting cable
post Aug 29, 2005 - 6:48 PM
cyb593
Joined Feb 22, '04
From USA
what parts am i missing here?? can anyone help me these are the shifting cable in the engine bay. they are missing parts what do i need there?? anyone help. this 5th gen gts had a 3sgte swapped into it unsure what transmission it has in it. i need part numbers or names of parts and from what car such as a celica alltrac or mr2 turbo. please need help thanks
This post has been edited by cyb593: Aug 29, 2005 - 6:49 PM
Replies (1 - 13)
post Aug 29, 2005 - 7:46 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
those cables are wrong buddy. You need to figure out what tranny that is, or moditfy that tranny to get those cables to fit.
I will return one day.
post Aug 29, 2005 - 8:19 PM
cyb593
Joined Feb 22, '04
From USA
they were connected with zip ties at first and the shifting worked so what do i have to do
post Aug 29, 2005 - 10:46 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
go to toyota and buy 6th gen GT shifter cables and two clips.
you should be all set after that.
DEF
post Aug 29, 2005 - 10:50 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
pull the the one off from the clutch line right there in the pic and see if that one works with the cables..
This post has been edited by rjbibeau: Aug 29, 2005 - 10:51 PM
post Aug 29, 2005 - 10:52 PM
Defgeph
Joined Apr 17, '03
From Rockland NY
the one for the clutch line is too small
you need clips for shifter cables.
post Aug 29, 2005 - 10:53 PM
rjbibeau
Joined Sep 6, '04
From oakdale Mn
they are different huh i didn't even realiize that when i pulled em off...only thing i can say is maybe a machine shop or some engineering skills to make your own
This post has been edited by defgeph: Aug 29, 2005 - 11:54 PM
post Aug 30, 2005 - 8:55 AM
cyb593
Joined Feb 22, '04
From USA
so this will really work this is on a 5th gen gts.
can someone tell me my options
QUOTE(defgeph @ Aug 30, 2005 - 3:46 AM)
DEF
[right][snapback]329293[/snapback][/right]
post Aug 30, 2005 - 9:47 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
you need to clearly explain what year car you have, engine, model and......
You need to find out what tranny you are using.
you need to go to the right forum, this is strictly 6th generation celicas.
If you own a 5th gen or this engine is installed in a 5th gen go over to celicatech. They have plenty of 5th geners over there.
Who did the swap? where did you find this car ?
DEF
post Aug 30, 2005 - 11:21 AM
cyb593
Joined Feb 22, '04
From USA
i have a 6gc and a 5th gen ok. its a celica they are pretty close related, now like i said i have a 5th gen GTS that has a 3sgte swapped in it like i said up top. i dont know who swapped i bought it from a private seller so i dont know if they changed trannys or what the seller got it swapped. i am trying to get it fixed. the 5th and 6th dont vary to much different and i posted over there to i was hoping i could get help here to. it seems like no one over there is really posting. i need to check it
post Aug 30, 2005 - 11:32 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
actually, there are many differences between 5th and 6th gen.
They are two totally different generations.
Like I said above those cables you have in there are wrong. I doubt you'll find any more help here about it. I would recommend talking to 5th gen swappers, ur bound to run into someone that had this same problem.
Or another option is to grind down those C's tranny so you can clip in the cables. I would try to find the right cables, but grinding is another option that I would see as a last resort.
Good luck I hope you figure it out
DEF
post Aug 30, 2005 - 11:37 AM
cyb593
Joined Feb 22, '04
From USA
well go to celicatech and look at my post under 5th gen then tell me if i am better off using this site or the other. the one post i got was "u need clips" that helps doesnt since one can help me i guess i need a different site. there are many differences but they dont change much over the years either. there is a couple different things but if u look at the main picture they didnt change much. and also isnt it weird they have the same engines.
post Aug 30, 2005 - 11:39 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
yes they have the same engine.
but the mounts, cables, axles, wiring, is all different.
post Aug 30, 2005 - 11:42 AM
Defgeph
Joined Apr 17, '03
From Rockland NY
I just looked at ctech
get the right cables, or grind the tranny to fit the ones you have installed.
DEF
Lo-Fi Version Time is now: January 10th, 2025 - 9:58 AM
