> turbo lines, vacuum and fuel cut defender
post Sep 16, 2005 - 5:59 AM
CheesyLobster
Joined Jul 19, '04
From Los Angeles, CA
im trying to figure out how to hook up my lines for my turbo project. I'm just a bit confussed about how all the lines split between the maps sensor, etc. please someone tell me how this all works. I read nik's writeup and it's too vague.
do i split the line that goes from the map sensor to the intake manifold, and T that a few times for the fmu, bov, and boost guage? if someone could draw it out for me that would be amazing. please help. thanks.
EDIT:: Also while im at it, i have a fuel cut defender (i think) that on the back has instructions. it says that my power wire though is to be 5 volts. should this be spliced into the 5 volt reference wire on the map sensor?
This post has been edited by CheesyLobster: Sep 16, 2005 - 10:27 PM
Replies (1 - 4)
post Sep 16, 2005 - 9:21 AM
nik
Joined Sep 30, '02
ok sorry that i wasnt detailed about it but here i'll break it down a little
map sensor line ( dont split off)
FMU or boost controllers ( the first black T is for my FMU and the second T white is for my greddy Profec E-01)
boost gauge and or bov (the line coming up over the TB is off the big line in the middle back of the manifold) look close
here a close up
all these pics are in the how to but i just need to rewrite the how to to be more detailed hope this helps
post Sep 16, 2005 - 9:23 AM
nik
Joined Sep 30, '02
QUOTE(CheesyLobster @ Sep 16, 2005 - 3:59 AM)
[right][snapback]334902[/snapback][/right]
no find power some where different dont splice in the map harness
post Sep 16, 2005 - 3:19 PM
CheesyLobster
Joined Jul 19, '04
thanks so much!
post Sep 16, 2005 - 10:26 PM
CheesyLobster
Joined Jul 19, '04
QUOTE(nik @ Sep 16, 2005 - 2:23 PM)
[right][snapback]334924[/snapback][/right]
the only 5 volt sources that i know of are the one on the map sensor and the one on the TPS. where can i find a 5v thats not being used by something else?
Lo-Fi Version Time is now: January 12th, 2025 - 4:17 AM
