> Very upset, dyno results
post Sep 16, 2005 - 11:34 AM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
ok, so i took my 7afTe to get dynoed today and was VERY unhappy with the results. at 8PSI it pulled a 93.5HP and 97.7Ft-lbs torque. thats less then stock!!! i have no clue what is wrong with my car. its def getting boost too because from 3-5 k u can feel it pull and then letting off the gas the BOV goes off. so i Have no clue what is wrong. if u have any idea whats goin on let me know. right now iam goin out to look at SRT-4s cuz i want a second car, this car just aint doin it for me.
3 Pages V   1 2 3 >
Replies (1 - 19)
post Sep 16, 2005 - 11:39 AM
SoundSlut_dotcom
Joined Feb 16, '03
QUOTE(StreetRacing10PSI @ Sep 16, 2005 - 9:34 AM)
[right][snapback]334956[/snapback][/right]
u just made me not want to turbo my car, iknew the turbo would end up doing sh!t ne way on a 7afe
post Sep 16, 2005 - 11:54 AM
sounds like you have a MAJOR problem, like a boost leak, or somthing.
post Sep 16, 2005 - 12:26 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
Yeah something isn't right.... You should go and re-check everything
post Sep 16, 2005 - 12:57 PM
nik
Joined Sep 30, '02
THERE IS NO WAY YOU SHOULD BE MAKING THAT LITTLE POWER ON 8 LBS
ok first check all connectors then check the pipe right below the turbo it has a little metal nipple make sure there is a rubber cap on it.
i just dont understand something is wrong i dyno tested that hole kit kit 3 times and 3 runs each time take detailed pictures of everything also check to make sure all the bolts on the turbo housing are tight
edit: those numbers should be your stock whp almost seems like a pipe might be loose between the intercooler to the TB or a massive boost leak recheck the everything from manifold bolts to vacum line connection
can you put up the DYNO chart so i can look at it
I mean at only 4.5 psi i made 126.95 whp and 162.03 torque
This post has been edited by nik: Sep 16, 2005 - 1:04 PM
post Sep 16, 2005 - 1:53 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
reset your ecu?
post Sep 16, 2005 - 2:15 PM
frosty
Joined Sep 1, '04
From Alabama
QUOTE(SoundSlut_dotcom @ Sep 16, 2005 - 4:39 PM)
[right][snapback]334957[/snapback][/right]
No, a turbo would work on a 7afe. As long as it's installed right it will work.
He's just having a difficulty, but I'm sure he''l find the problem soon then it will be awesome!
CLOSED on 25 acres!
-shop coming soon....
post Sep 16, 2005 - 2:43 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
QUOTE(nik @ Sep 16, 2005 - 1:57 PM)
[right][snapback]334978[/snapback][/right]
Their is no rubber cap on the nipple, i dnt think their ever was either. iam goin to try and find somin that will fit on their and see if that helps
post Sep 16, 2005 - 2:46 PM
QUOTE(Jdog1385 @ Sep 16, 2005 - 1:53 PM)
reset your ecu?
[right][snapback]335001[/snapback][/right]
aw man that response makes me wanna smack my head against a wall....
what made you say that...........
post Sep 16, 2005 - 2:52 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
QUOTE(playr158 @ Sep 16, 2005 - 3:46 PM)
[right][snapback]335021[/snapback][/right]
post Sep 16, 2005 - 3:07 PM
nik
Joined Sep 30, '02
hey do you have a cell phone version or cinglar STREETRacing10psi
post Sep 16, 2005 - 3:44 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
QUOTE(nik @ Sep 16, 2005 - 4:07 PM)
[right][snapback]335032[/snapback][/right]
Yea i have verison Pm me for the # if u want, but i think i found out the problem. i took out my spark plug wires and the 1st and 2nd 1's are completly shot. these wires are new too and cost me $130.00. i took them out and they completly fell abart into 4 pieces. thats probly the problem cuz if it was runnin on 2 pistons then 1/2 the power would only b around 90HP any way. iam goin to go out now and buy new stock wires for now and see if thats the problem.
post Sep 16, 2005 - 4:39 PM
Jdog1385
Joined Apr 14, '03
lol, i was joking but on a serious note my buddy had a problem with his ecu and it was restricting horsepower
post Sep 16, 2005 - 4:48 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
just for ****s and giggles its verizon and cingular
post Sep 16, 2005 - 5:13 PM
nik
Joined Sep 30, '02
QUOTE(celicast3sgte @ Sep 16, 2005 - 2:48 PM)
[right][snapback]335079[/snapback][/right]
This post has been edited by nik: Sep 16, 2005 - 5:16 PM
post Sep 16, 2005 - 5:53 PM
nik
Joined Sep 30, '02
QUOTE(StreetRacing10PSI @ Sep 16, 2005 - 1:44 PM)
[right][snapback]335049[/snapback][/right]
my girls got verison but anyways did those new wires fix your problem?
post Sep 16, 2005 - 10:19 PM
note, the MR2 very high HP guys will tell you "always use OEM Toyota plug wires"
no jive
post Sep 16, 2005 - 11:20 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
i replaced the wires and brought it to the track and at 8psi ran a pathetic 17.770 so the car seems like it is still around 90 HP
Edit: my second run was a 22.8 cuz my car wouldnt shift into 3rd gear on the automatic and it started to miss fire. ended up that a spark plug wire was loose but the car still seems the same. i even cloged the hole one the IC piping. Still have no clue whats goin on
This post has been edited by StreetRacing10PSI: Sep 16, 2005 - 11:31 PM
post Sep 16, 2005 - 11:58 PM
ArizonaRed
Joined Sep 17, '03
From Tampa FL
QUOTE(Batman722 @ Sep 17, 2005 - 3:19 AM)
no jive
[right][snapback]335222[/snapback][/right]
I used to have aftermarket wires, i was recommended to go back to oem by my mechanics.
QUOTE(StreetRacing10PSI @ Sep 17, 2005 - 4:20 AM)
[right][snapback]335250[/snapback][/right]
Do you have a kit from Nik? Is it the same that hes got? I'd just check everything one by one. fuel problem, intake clog, exhaust restriction.
-97 Celica ST
-2001 Celica GTS dk blue mica 100hp per litre
(GOT LIFT?)
post Sep 17, 2005 - 12:40 AM
BBoYRuGGeD
Joined Jun 4, '04
From Northern New Jersey
hmmm very strange... i hope u find the problem asap. like nik said... the 7afe has potential when a turbo is slapped on it, its just that theres prolly something going on that u havent come across yet. anyway goodluck!
bboy
3 Pages V   1 2 3 >
Lo-Fi Version Time is now: February 21st, 2025 - 2:03 PM
