> alignment, is it true
post May 4, 2003 - 7:58 PM
Dickster223
Joined Dec 5, '02
From West Virginia
is it true that u have to get a four wheel alignment done on ur car when u put on coil overs
Replies (1 - 2)
post May 4, 2003 - 10:19 PM
Milds3vn
Joined Feb 11, '03
From Phila, PA
Yea if you want to be proactive about tyre wear and handling, anytime you mess with the suspension you could and probably have messed up the allignment, depending on your coilovers you might want to look into a camber kit to save your tyres. Have you had your wheels balanced? Might want to do that to if you just got rims or tires. You can never be to careful about the only 4 things that touch the road.
post May 4, 2003 - 11:06 PM
macavely
Joined Nov 4, '02
Yup anytime you change anything with the suspension you should get your car an alignment. you might not need it but you can never be to carful when it comes to your suspension and tires.
Lo-Fi Version Time is now: November 25th, 2024 - 9:44 AM
