Enthusiast ![]() ![]() Joined Jan 16, '04 From sydney australia Currently Offline Reputation: 0 (0%) ![]() |
[B]Guys i need some info on the dash here is what i need....
1. ohms of fuel tank empty and full..??? 2. water temp on idle..??? 3. what oil pressure range would i need to get..??? -------------------- ![]() 312whp with more to come.... |
Enthusiast ![]() ![]() ![]() Joined Nov 18, '02 From Texas Currently Offline Reputation: 0 (0%) ![]() |
I think on the fuel gauge, if you get the universal kit, it will work (240 full, 33 empty). You'll have to install it in the tank, but I'm pretty sure it will work. You'll need the fuel level sender also to make this gauge work.
I'm not sure on the water temp, but should be around 200 +/- 20 (degrees F), so the gauge with 100-250 range should be great. The oil pressure gauge to get would be the 0-100 psi most likely unless you want it in bars. All of these also depend on if you are wanting mechanical or electrical gauges. I've been researching this somewhat because I plan on changing out all mine, so if you have any other questions feel free to let me know. |
Lo-Fi Version | Time is now: February 24th, 2025 - 6:42 AM |
