> oil catch can?, someone explain
post Oct 7, 2005 - 9:39 PM
urbandork
Joined Jul 16, '04
From Los Angeles
I know they go between the valve cover and intake, but what do they do, how do they work, whats the point, and is it a FI or NA only mod???? do they drain in to the oil pan? or do u ahve to take off the can and poor it out?
confused......
Replies (1 - 7)
post Oct 7, 2005 - 9:52 PM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
- The Oil Catch can is used to reduce the oilvapours from going into the air intake charge.
- The oil vapours will contiminate the intake charge by mixing with the air and fuel that are used to create combustion.
- This would reduce burn efficiency and increase detonation risk in both turbo or non-turbo cars
- As contamination usually occurs before peak torque, it would affect power in both turbo and n/a set-up
6GC 4 Life Baby!!!
post Oct 8, 2005 - 12:13 PM
urbandork
Joined Jul 16, '04
From Los Angeles
how is the can emptied? can u make a drain for it to the pan?
post Oct 8, 2005 - 12:39 PM
QUOTE(urbandork @ Oct 8, 2005 - 1:13 PM)
[right][snapback]342486[/snapback][/right]
you would just the the can off and empty. Real easy.
post Oct 8, 2005 - 12:42 PM
the can is there to catch excess oil blow by that can happen on some turbo cars. normally that oil just shoots back into the intake and onto the turbo. if its a lot of blow by it can turn into blue smoke coming out of your tail pipe. installing a catch can just helps keep things nice and clean. it wont help preformance in any way tho.
post Oct 8, 2005 - 8:16 PM
celicast3sgte
Joined Jul 10, '05
From Monroe, WA
isnt cleaner better tho? just curious. i might consider a catch can by end of next year when i start upping the boost.
post Oct 8, 2005 - 8:51 PM
i guess it depends on how much blowby you are getting out of the valve cover. normally, you shouldnt really need it for anything. i dont have one of my car, the oil just goes right into the turbo intake. its only like a table spool full in there at most, after months of driving.
post Oct 9, 2005 - 12:31 PM
TrdKing
Joined Feb 16, '05
From Brantford, Ontario, Canada
i replace my line from the valve cover to the throttle body with some red silicone stuff and after 7000 kms i took it off and looking inside and it was still really clean.
Lo-Fi Version Time is now: January 10th, 2025 - 11:42 AM
