water to air intercooler, parts needed? |
Nov 1, 2005 - 10:16 PM |
Enthusiast Joined Feb 22, '04 From USA Currently Offline Reputation: 3 (100%) |
i got the water to air intercooler and i dont have anything but the intercooler and i am switching from air to air to water to air because i dont have a hood scoop for air to get to it. anyways what do i need to use for the radiator fluid??? and to keep it moving what parts can someone show pics of what i need and part numbers or something any help would be great thanks.
Nov 1, 2005 - 10:18 PM |
Enthusiast Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) |
You will need a heat exchanger and appropriate piping.
-------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Nov 1, 2005 - 10:22 PM |
Moderator Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
A water pump would help too
-------------------- I will return one day. |
Nov 1, 2005 - 10:33 PM |
Enthusiast Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
anyone ever make there own with a pwr setup?
Nov 1, 2005 - 10:43 PM |
Pump IC Radiator Lines Intercooler You can manufacture the lines, you can even get a different pump which is stronger. If you are using your car year 'round, get a mix of antifreeze and water, of if you love toyota you can pay for their red mix. This post has been edited by Supersprynt: Nov 1, 2005 - 11:26 PM -------------------- |
Nov 2, 2005 - 11:47 AM |
k so can i someone give me a idea of how much those parts will cost i got the the intercooler. anyone have parts i can buy from someone?? dont want o spend a ass load of money on it shouldnt i already have the part 16290 it looks like it connects up to the radiator. i need more help i see the parts but i need them and need to see this what what other kind of pump can i use??
Nov 2, 2005 - 12:18 PM |
Ok well 16290 is the pump, and do a search about that on MR2oc and Alltrac.net they'll have info for you. The rest I basically spelled out for you.
This post has been edited by Supersprynt: Nov 2, 2005 - 12:23 PM -------------------- |
Nov 2, 2005 - 1:35 PM |
Enthusiast Joined Sep 1, '04 From Alabama Currently Offline Reputation: 0 (0%) |
just out of curiosity, are you putting it on your daily driver? I ask because I read that for it to work best you have to change out the water pretty often, but of course, that's only what I read. I know the purpose of an air to water and some details but I haven't really gone in deep review of them so this is why I ask.
-------------------- CLOSED on 25 acres! -shop coming soon.... |
Nov 2, 2005 - 2:17 PM |
no daily driver maybe like twice a week but nothing more
Nov 2, 2005 - 2:51 PM |
Enthusiast Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
QUOTE(frosty @ Nov 2, 2005 - 1:35 PM) just out of curiosity, are you putting it on your daily driver? I ask because I read that for it to work best you have to change out the water pretty often, but of course, that's only what I read. I know the purpose of an air to water and some details but I haven't really gone in deep review of them so this is why I ask. [right][snapback]351986[/snapback][/right] Eh? 1) Runs the same coolant as the main rad uses 2) I change mine with the rest of the fluids about once every 24 months. -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Nov 2, 2005 - 3:08 PM |
Eh, like I said, I'm still learning about this form of cooling
Nov 2, 2005 - 10:16 PM |
It basically works like your coolant system except more simple. Water goes thru IC radiator, cools, just like your reg. radiator, then goes up to your intercooler where the cool water which is a better heat conductor than air, cools the pressurized air from the turbo.
Nov 2, 2005 - 10:23 PM |
Enthusiast Joined Jan 8, '05 From Alabama Currently Offline Reputation: 0 (0%) |
how much more effictive is it then say a greddy fmic
Nov 3, 2005 - 1:11 AM |
QUOTE(MonsterBOX @ Nov 2, 2005 - 10:23 PM) how much more effictive is it then say a greddy fmic [right][snapback]352287[/snapback][/right] Read this -------------------- I will return one day. |
Nov 3, 2005 - 10:12 AM |
I guess what I read about was an aftermarket intercooler. I have no idea, I'll just have to find the article again to be sure.
Lo-Fi Version | Time is now: January 12th, 2025 - 9:02 PM |
