valve quote |
valve quote |
Nov 7, 2005 - 1:06 PM |
Enthusiast Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
I don't really think its that hard. If you need a head gasket replacement, than I think you just remove the head and then scrap off gasket and put on new one and put back the head Minus removal of all belts and what not. Too an car illlitrate guy like me, I would probbaly have to remove the whole engine, cause it would be so much eaiser than to wiggle your way around the engine while its still in the car.
Nov 7, 2005 - 3:47 PM |
Enthusiast Joined May 24, '03 From Milton, Delaware Currently Offline Reputation: 0 (0%) |
I believe replacing the headgasket is actually a fairly decent sized job. You'll need to pull the motor to do it most likely (to get at stuff), if you're gonna bother doing that u may want to go ahead and replace the coolant pump belts, timing etc...
Thats just what i think tho... -------------------- AIM : FAQdaWorld
Lo-Fi Version | Time is now: January 17th, 2025 - 1:03 AM |
