Tyre Wear..., ...on performance cars. |
May 12, 2003 - 1:52 AM |
Enthusiast Joined Apr 28, '03 From London Currently Offline Reputation: 0 (0%) |
Stupid question perhaps?
Do tyres wear out more on the inside of the wheels more than on the outside (I'm talking on fat racing wheels), or is that to do with the tracking of the car needing adjusting? Somebody fed me this info and I thought 'bollox, don't believe you!'. Should I believe or sort tracking out? jaq1967 |
May 12, 2003 - 2:04 AM |
Enthusiast Joined Aug 29, '02 From Franklin/Nashville, TN Currently Offline Reputation: 16 (100%) |
it has to do w/ a camber problem when a car is lowered excessively w/o being aligned and straightened out. when you drop the car X amount, it changes all the angles, and the tops of the tires tend to lean in, therefore causeing the inside of the tire to take all of the contact on the road, and sometimes the outside doesn't even touch the road, thus causing the excessive wear on the inside . but, if taken care of, this will not happen. if you lower the car or somethin like that, be sure to get it aligned. .
-John- -------------------- |
Enthusiast Joined Nov 4, '02 From Hecho en la Republica Dominicana/Living in NJ Currently Offline Reputation: 0 (0%) |
if the tire wire on more on the inside or outside tired that has to do whit the camber, and if the car turn more to one side then the other. hope that helps
May 12, 2003 - 2:05 AM |
BEAT YOU! heheheh. :-p -------------------- |
May 12, 2003 - 11:40 PM |
Enthusiast Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
If your car is not lowered and you are getting uneven wear, get your wheels alligned and balanced.
Lo-Fi Version | Time is now: November 24th, 2024 - 7:03 AM |
