> Higher Octaine, ignition advancing
post May 14, 2003 - 4:05 PM
skydrol
Joined May 12, '03
From Travis AFB
for the 7A-FE motor, is there a ignition advancing degree that some one has found to use higher octaine fuel like 87 or even 91? i know there is one for the 3S-GE motor, i was wondering if it also will work for the 7A-FE ST motor. just trying to get every little bit i can out of this weak ass motor.
thanks in advance.
Replies (1 - 10)
post May 14, 2003 - 6:30 PM
ghostdog
From ny to philly
apparently you can run +12 timing on regular 87 octane fuel. as for higher octane, I think you are safe up to +14 or 15 timing, but I'm not 100% sure so don't quote me on that.
post May 14, 2003 - 8:56 PM
skydrol
Joined May 12, '03
From Travis AFB
so, the manual says that stock timming degree is +10, right? but the engine will run fine advancing timming +12 to 15 degrees? can anyone ells verify this?
post May 14, 2003 - 11:54 PM
ghostdog
From ny to philly
okay so 14 might be the highest you want to go. if you advance too much you'll get knock causing the ecu to retard the timing (defeating the purpose of advancing it in the first place).
so I would say 14 with high octane and 12 with regular. anyone else got thoughts on this?
post May 15, 2003 - 10:33 AM
skydrol
Joined May 12, '03
From Travis AFB
so +14 on timming advance?
yes, does anbody ells have a say on this?
post May 15, 2003 - 5:52 PM
HyperDeathKill
Joined Apr 20, '03
From Chicago
What's that gonna do for ya HP wise? Advancing the timing?
post May 15, 2003 - 7:18 PM
west_minist
Joined Oct 27, '02
From Barbados
I could tell you how to do it, but you would not want to hear and do since you have all the info to do it to the 3sge engine.
Hint, get a timing light gun w/ adjustable timing control
West_Minist
Hydra EMS Dealer & Tuner
Subaru ECUFlash Tuner
http://www.socob.bb
http://xtremeracingtuning.com
Viciously Tuned, Driven Hard
post May 15, 2003 - 11:04 PM
skydrol
Joined May 12, '03
From Travis AFB
okay, i see how it is here
post May 15, 2003 - 11:54 PM
ghostdog
From ny to philly
QUOTE (skydrol @ May 15, 2003 - 8:18 PM)
hey man, people aren't ignoring you, this is just an obscure question. however I can tell you that advancing your timing beyond 14 really isn't worth it. you risk detonation and its not going to gain you much hp anyway.
hope that helps.
post May 16, 2003 - 6:39 AM
seth042280
Joined Mar 31, '03
From cary . north carolina
I want to advance my paycheck.
post May 16, 2003 - 11:40 AM
skydrol
Joined May 12, '03
From Travis AFB
oh, no big deal. i was only kidding. i guess i should have said that. maybe theres no point in advancing the timming after all. who want tos pay more for gas anyway!?!
Lo-Fi Version Time is now: November 28th, 2024 - 12:49 PM
