> 7afe head/block
post Dec 10, 2005 - 5:04 PM
TrD3sgte94
Joined Dec 4, '04
From just moved from houston to austin
i just pulled all kinds of parts out of my st and now i cant seem to find out how to get the head off. everything is disassembled off of the head, do i need to take off the camshaft and take out the bolts underneath? any help will be much appreciated...
-wess-
[SIZE=7][COLOR=blue][SIZE=1]-WES-
Replies (1 - 6)
post Dec 10, 2005 - 6:02 PM
did you remove the timing belt?
post Dec 10, 2005 - 6:13 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
You need to remove timing belt, remove cam caps, remove cams, then remove head bolts (located under camshafts)...
post Dec 10, 2005 - 6:59 PM
TrD3sgte94
Joined Dec 4, '04
yes i pulled the timing belt off it was like the first thing i did and now i have pulled the caps and camshaft's off i just now can find a 12point 10mm socket to fit the headbolts underneath the camshafts. thanks for the help guys
post Dec 11, 2005 - 3:38 AM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
Could somebody point me to the direction in how to remove the crankpulley the poor way, cause I can't find the tool needed to remove it.
post Dec 11, 2005 - 10:00 AM
QUOTE(soulshadow @ Dec 11, 2005 - 3:38 AM) [snapback]365776[/snapback]
when i did my first, it was outta the bay, and i used a long breaker bar, and hit it with a hammer, REALLY hard..so that the engine wouldnt rotate, but the bolt loosened.
that was on a '98 motor, tho.
every time since, ive had to use an air gun.
post Dec 11, 2005 - 7:37 PM
TrD3sgte94
Joined Dec 4, '04
i didnt even get around to taking it out today because i was trying to figure out why my 94 eclipse wasnt idling right...
Lo-Fi Version Time is now: January 12th, 2025 - 12:27 AM
