> Install: rear sway / stabilizer bar, quick write up
post Dec 17, 2005 - 8:50 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
Note: This how-to and its associated photos are now located at this url:
http://www.6gc.net/howto/install_rear_sway_bar
-Christian Coomer, Administrator
looking thru this site there was nothing for ->
things to watch out for when installing rear sway bar.
oem vs suspension technique
o man do i need a disc conversion lol either that or sand/paint the drum.<p>
sway bar hits exhaust pipe -> must be removed.
U-Clips removed from bushings.
watch for the flange as it has one nut welded to it. the other is bolt/nut combo
used wd-40 for lubricant & just removed rubber-hanger support from rear of exhaust 1 of 3 rubber hangers.
2 small screws should take care of that
my pea shooter.
fuel tank straps were removed. fuel tank dropped about 1.5" - held up by jack & wood block.
watch for these as they might get caught but shouldn't be a threat.
tilt your head for this one. much more space after removing the muffler
POOF! no more oem sway bar! it was a sinch to remove.
voila! suspension technique sway bar in place ready for install.
be liberal with the grease
these bushings are huge compared to stock
had a weird time putting this bushing U-clip on because the bolt came too close to the hump
feels great to drive
gL on your install
Replies (1 - 19)
post Dec 18, 2005 - 12:55 AM
Bigmeanbulldog55
Joined Jun 1, '03
From WV
Great! This had better get made into a "how to." There's a few things I thought should have made it into the "how to's," but I see no reason at all this shouldn't.
Live Free, Be Happy
post Dec 18, 2005 - 7:53 PM
Jdog1385
Joined Apr 14, '03
From Long Island, N.Y.
nice write up
post Dec 20, 2005 - 8:05 AM
good job, man, ill add this to the stickys!
post Dec 20, 2005 - 8:22 AM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
You may not have to remove the muffler if you have an aftermarket unit. I did not with my HKS setup that goes under the suspension. Just FYI if this becomes a how-to.
post Jan 3, 2006 - 11:19 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
How does it feel, before and after the install. Im looking for some difference to make a supension upgrade on my car.
post Jan 4, 2006 - 2:17 AM
urbandork
Joined Jul 16, '04
From Los Angeles
muuummm yummy
post Jan 4, 2006 - 2:46 AM
Magic
Joined Mar 30, '03
From Cyprus
Great How-to smile.gif Nice and clear photos....
How does it feels??
It is good to see owners to improve the car handling
post Jan 5, 2006 - 4:57 AM
purplegt4
Joined Feb 7, '03
wise man once said: If it feels like you're riding on rails, you're not driving fast enough.
noticeable change in oversteer @ high speed 60+mph highways exits
when i got my alignment done, the tech changed the settings on the rear sway bar [to outer oversteer setting]. i tried something i did usually in my car on a high speed exit (+60mph) and the front end became unstable [as opposed to back end "swinging/slipping/pivot" out].
This post has been edited by purplegt4: May 25, 2006 - 6:30 PM
post May 21, 2006 - 8:41 PM
JoKeRkId613
Joined Apr 25, '03
From Miami, FL
what's better? oversteer or understeer. i dont care about fwd/rwd, i want to know about which one's better on the celica. im kinda lazy to search and am really just looking for a very brief definition of both and why one is better than the other for daily driving. thanks.
p.s. im planning on putting on both front and rear sways, if that helps.
This post has been edited by JoKeRkId613: May 21, 2006 - 8:41 PM
post May 21, 2006 - 11:18 PM
Valo666
Joined May 15, '05
From Toronto
hmm...this could be a problem for me. My exhaust doesnt unbolt..its pretty much welded as one peice from my headers back. theres probably a way to manover it around the exhaust pipe
post May 23, 2006 - 2:31 PM
Speeder
Joined Apr 29, '04
From Norway
What about the horisontal brace between the swaybar and damper?
Is shis the OEM part? Is seems so weak...
I have just put on D2Racing coilovers, and this will be my next uppgrade.
Toyota Celica 2.0GT 1995 - 175BHP
- D2Racing coilovers - BlackDiamond brakes - TOYO R881 tires -
post May 25, 2006 - 6:26 PM
purplegt4
Joined Feb 7, '03
QUOTE(JoKeRkId613 @ May 21, 2006 - 9:41 PM) [snapback]436446[/snapback]
all depends on how you drive. cars were made with more understeer/push to make for safer driving.
QUOTE(Valo666 @ May 22, 2006 - 12:18 AM) [snapback]436502[/snapback]
took me a while to figure out that it's almost impossible...gL on that one.
QUOTE(Speeder @ May 23, 2006 - 3:31 PM) [snapback]437125[/snapback]
the swaybar endlink? it should be fine. never had one totally bend/break on me and i drive damn hard.
post Jun 14, 2006 - 2:14 AM
Speeder
Joined Apr 29, '04
From Norway
QUOTE(purplegt4 @ May 25, 2006 - 11:26 PM) [snapback]437993[/snapback]
So you use the stock endlink, there is no upgrade for this part?
post Jun 14, 2006 - 12:49 PM
purplegt4
Joined Feb 7, '03
QUOTE(Speeder @ Jun 14, 2006 - 3:14 AM) [snapback]444457[/snapback]
not that i know of. shouldn't really need it as the sway bar/strut is absorbing most of the action.
post Jul 2, 2006 - 6:29 PM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
how u do the fronts????....any pics of that too???.....how u managed to manuever it in front?
post Jul 2, 2006 - 10:50 PM
wow, thanks for all the pictures!
post Jul 3, 2006 - 9:53 AM
Kadett
Joined Mar 17, '05
From The Netherlands
If you want upgraded endlinks you can either chose for the Whiteline universal 90-115 mm endlinks (about 130 USD) or these
http://www.racingbeat.com/resultset.asp?PartNumber=54200
Are meant for a Mazda Miata/MX5 but have the same (10,5 or 10,8 cm) length as the stock Toyota Endlinks.
post Jul 3, 2006 - 11:04 AM
DeW_H0e_GT
Joined Mar 9, '05
From Oakland, Cali
QUOTE(Kadett @ Jul 3, 2006 - 9:53 AM) [snapback]451586[/snapback]
but will they swap over???
post Jul 3, 2006 - 11:11 AM
Kadett
Joined Mar 17, '05
Would not post them if I thought they weren't suitable for our cars now would I biggrin.gif
ST185 owners use them when they get a stiffer rear sway bar. The "Miata" endlink is between 10,5-10,8 cm from "eye to eye" I measured my own Endlink and its the same. Dont think US has a different size endlink.
And the Miata endlink is adjustable +/- 2/3mm The Whiteline Universal endlinks from 90-115mm so enough room to get them precisly as long as our stock ones.
Lo-Fi Version Time is now: November 30th, 2024 - 7:35 PM
