> GPS & Satellite Radio, Where did you mount your antenna?
post Jan 4, 2006 - 7:13 PM
djultimate
Joined Dec 1, '05
From South Windsor, CT
I'm gonna be installing Sirius and a GPS navagation system and I'm trying to get some ideas on where to put the antennas for each. The manufacturer says that you shouldn't paint them. Any ideas?
This post has been edited by djultimate: Jan 5, 2006 - 1:24 PM
Replies (1 - 9)
post Jan 5, 2006 - 1:06 AM
djultimate
Joined Dec 1, '05
no ideas? If it's gonna be inside, it needs to be near a window in order to get the signal.
post Jan 5, 2006 - 2:17 AM
Zimluura
Joined Feb 3, '05
From USA/Virginia
near a window that rolls down or just near some glass? no experience with it myself. but i'd just try using double sided tape in a variety of locations, and see what gives pest performance. maybe on the front of the dash. our windshields are pretty big and sloped so that might be enough of an opening to get good reception.
post Jan 5, 2006 - 5:52 PM
RocketScott
Joined Nov 21, '05
From Tacoma, WA
Will the wire fit between the gap in the hatch and the body? You could put it in the center just forward of the hatch as long as it doesn't leak. It's just a little black box isn't it? I've only seen a couple of the sirius setups before.
post Jan 5, 2006 - 6:00 PM
djultimate
Joined Dec 1, '05
Well, I was trying to avoid putting them on the OUTSIDE cuz they are kinda ugly. Not to mention some a-hole could come along and rip the thing right off the car just to be a d1ck. So I was thinking about finding a place INSIDE the car to mount them. Yes they are little black boxes about the same height as a credit card but half the length. One for GPS and one for Sirius.
I might just end up mounting one on each front corner of the dash.
post Jan 5, 2006 - 7:36 PM
djultimate
Joined Dec 1, '05
Ok even if i want to run the antenna out by the hatch/roof, I can't do it cuz the plugs for the antennas won't fit through the gap at the top of the hatch. I would have to take the hatch off in order to do it.
post Jan 7, 2006 - 11:38 PM
TwistedmindZ
Joined Dec 21, '05
From SF Cali
i have both my XM and GPS antenna's inside my gps antenna is centered and my xm is in the corner. with my past experiences with sirius though is that they don't have as many ground repeaters as xm so it gets better reception on the outside of the car, my favorite mounting spot would be in the middle in front of the sunroof.
post May 20, 2006 - 11:31 AM
toyotacrazy
Joined Mar 4, '06
From Ohio
hey
I just installed satellite radio in my hatchback celica. I put the antenna just infront of the rear window washer nossle. The antenna reciever is magnetic. I ran the wire into the closest crack between the hatch and roof panel. then I ran the wire to the rubber washer hose insulator. Using a zip tie secure it there. Run it over toward the drivers side along the hatch to the other rubber wire insulator. Then also zip tie it there. Run the wire around hinge and under the rubber hatch seal and then under the healiner or plastic trim panel all the way to the front. It looks really good and you cant see the wires hardly at all. If you want pics let me know. Hope this helps. let me know.
post May 27, 2006 - 8:53 AM
eliaz
Joined Dec 28, '05
From Norway
I put mine on the dashboard, far in the right corner near the window. I have a Pioneer Avic-X1r and i works great.
post Jun 21, 2006 - 1:05 AM
DomGT
Joined Apr 19, '06
From Long Island, NY
My Sirius antenna is on the top-most flat section of the passanger side front fender. smile.gif I like it there.
'92 Grey Mitsubishi 3000GT SL - Sold
'96 Black Celica ST 25th Anniversary - Sold
'99 Black Mitsubishi 3000GT VR-4 - Sold
'04 E250 Work Van - Going soon
'08 Grey Dodge Charger Work Car - Ordered
Lo-Fi Version Time is now: February 22nd, 2025 - 11:17 AM
