> Maintenace?
post Jan 5, 2006 - 12:40 AM
o0black0o
Joined Jul 14, '05
From Spring, Texas
Does anyone have a compelete list of what maintenace needs to be done on what miles? If so please be spefic and detailed about it.
Im thinking my car needs a certain tune up cause its running pretty ****ty right now on my point of view. It has 160k on it. Engine was rebuild though. Im not exactly sure how many miles are on it. Is there a way to tell how many miles are on the engine? Thanks Guys
Replies (1 - 5)
post Jan 5, 2006 - 4:58 AM
macavely
Joined Nov 4, '02
SCHEDULED SERVICES - NON-TURBO
1994 Toyota Celica
1990-96 MAINTENANCE
Toyota Maintenance & Service Intervals (Non-Turbo)
Celica
* PLEASE READ THIS FIRST *
NOTE: All SERVICE SCHEDULES are listed for normal service
vehicles. If vehicle is operated under severe service
conditions, see SEVERE SERVICE REQUIREMENTS (PERFORM
W/SERVICE SCHEDULES) for items requiring additional
maintenance.
NOTE: This article contains scheduled maintenance service
information. Fluid types and capacities listed with each
service in this article are only those necessary to perform
that scheduled service. For specifications pertaining to
fluid capacities for the entire vehicle, fuse and circuit
breaker identification, wheel and tire size, battery type,
warranty information, or model identification refer to the
MAINTENANCE INFORMATION article in this section.
CAUTIONS & WARNINGS
SUPPLEMENTAL RESTRAINT SYSTEM (AIR BAG)
NOTE: See the AIR BAGS article in the ACCESSORIES/SAFETY EQUIPMENT
Section.
Modifications or improper maintenance, including incorrect
removal and installation of the Supplemental Restraint System (SRS),
can adversely affect system performance. DO NOT cover, obstruct or
change the steering wheel horn pad in any way, as such action could
cause improper function of the system. Use only plain water when
cleaning the horn pad. Solvents or cleaners could adversely affect the
air bag cover and cause improper deployment of the system.
WARNING: To avoid injury from accidental air bag deployment, read and
carefully follow all warnings and service precautions. See
appropriate AIR BAGS article in ACCESSORIES/SAFETY EQUIPMENT.
CAUTION: Disconnect negative battery cable before servicing any air
bag system, steering column or passenger side dash
component. After any repair, turn ignition key to the ON
position from passenger’s side of vehicle in case of
accidental air bag inflation
AIR CONDITIONING SERVICING
CAUTION: Avoid breathing R-134a refrigerant and PAG lubricant vapors,
exposure may irritate eyes, nose and throat. To remove
R-134a from system use R-134a recycling equipment that meets
SAE J2210 specifications. If accidental system discharge
occurs, ventilate work area before resuming service.
WARNING: R-134a service equipment or vehicle A/C systems SHOULD NOT
be pressure tested or leak tested with compressed air. Some
mixtures of air/R134a have shown to be combustible at
elevated pressures. These mixtures are dangerous and may
cause fire and/or explosions. See AIR CONDITIONING SERVICE
article in GENERAL INFORMATION section.
ANTI-LOCK BRAKE SYSTEM
The anti-lock brake system contains electronic equipment that
can be susceptible to interference caused by improperly installed or
high output radio transmitting equipment. Since this interference
could cause the possible loss of the anti-lock braking capability,
such equipment should be installed by qualified professionals.
On models equipped with anti-lock brake systems, ALWAYS
observe the following cautions:
* DO NOT attempt to bleed hydraulic system without first
referring to the appropriate ANTI-LOCK BRAKE SYSTEM article
in the BRAKES Section.
* DO NOT mix tire sizes. As long as tires remain close to the
original diameter, increasing the width is acceptable.
Rolling diameter must be identical for all 4 tires. Some
manufacturers recommend tires of the same brand, style and
type. Failure to follow this precaution may cause inaccurate
wheel speed readings.
* Use ONLY recommended brake fluids. DO NOT use silicone brake
fluids in an ABS-equipped vehicle.
BATTERY WARNING
WARNING: When battery is disconnected, vehicles equipped with
computers may lose memory data. When battery power is
restored, driveability problems may exist on some vehicles.
These vehicles may require a relearn procedure. See COMPUTER
RELEARN PROCEDURES article in GENERAL INFORMATION section.
REPLACING BLOWN FUSES
Before replacing a blown fuse, remove ignition key, turn off
all lights and accessories to avoid damaging the electrical system. Be
sure to use fuse with the correct indicated amperage rating. The use
of an incorrect amperage rating fuse may result in a dangerous
electrical system overload.
BRAKE PAD WEAR INDICATOR
Indicator will cause a squealing or scraping noise, warning
that brake pads need replacement.
CATALYTIC CONVERTER
Continued operation of vehicle with a severe malfunction
could cause converter to overheat, resulting in possible damage to
converter and vehicle.
Any modification to the exhaust system on turbo models, which
reduces exhaust backpressure, will lead to lean fuel mixtures and
excessive spark advance. This could cause serious engine damage.
ELECTROSTATIC DISCHARGE SENSITIVE (ESD) PARTS
WARNING: Many solid state electrical components can be damaged by
static electricity (ESD). Some will display a warning label,
but many will not. Discharge personal static electricity by
touching a metal ground point on the vehicle prior to
servicing any ESD sensitive component.
ENGINE OIL
CAUTION: Never use non-detergent or straight mineral oil.
FUEL SYSTEM SERVICE
WARNING: Relieve fuel system pressure prior to servicing any fuel
system component (fuel injection models).
HALOGEN BULBS
Halogen bulbs contain pressurized gas which may explode if
overheated. DO NOT touch glass portion of bulb with bare hands. Eye
protection should be worn when handling or working around halogen
bulbs.
RADIATOR CAP
CAUTION: Always disconnect the fan motor when working near the
radiator fan. The fan is temperature controlled and could
start at any time even when the ignition key is in the OFF
position. DO NOT loosen or remove radiator cap when cooling
system is hot.
RADIATOR FAN
WARNING: Keep hands away from radiator fan. Fan is controlled by a
thermostatic switch which may come on or run for up to 15 minutes even
after engine is turned off.
TURBOCHARGED MODELS
CAUTION: Do not race engine immediately after starting. When
stopping engine, allow engine to idle for approximately 60
seconds before shutting it off. Failure to do so may cause
turbocharger damage due to lack of oil flowing to
the turbocharger bearings.
SERVICE POINT LOCATIONS
Fig. 1: Service Point Locations (5S-FE Engine)
Courtesy of Toyota Motor Sales, U.S.A., Inc.
Fig. 2: Service Point Locations (4A-FE Engine)
CAMSHAFT TIMING BELT REPLACEMENT INFORMATION
CAUTION: Failure to replace a faulty camshaft timing belt may result
in serious engine damage.
The condition of camshaft drive belts should always be
checked on vehicles which have more than 50,000 miles. Although some
manufacturers do not recommend belt replacement at a specified
mileage, others require it at 60,000-100,000 miles. A camshaft drive
belt failure may cause extensive damage to internal engine components
on most engines, although some designs do not allow piston-to-valve
contact. These designs are often called "Free Wheeling".
Many manufacturers changed their maintenance and warranty
schedules in the mid-1980’s to reflect timing belt inspection and/or
replacement at 50,000-60,000 miles. Most service interval schedules in
this manual reflect these changes.
Belts or components should be inspected and replaced if any
of the following conditions exist:
* Cracks Or Tears In Belt Surface
* Missing, Damaged, Cracked Or Rounded Teeth
* Oil Contamination
* Damaged Or Faulty Tensioners
* Incorrect Tension Adjustment
Replace the camshaft timing belt every 72 months or 60,000
miles if the vehicle is operated under Severe Service conditions such
as frequent idling or extensive long distance driving at low speeds
(taxi, police or door-to-door delivery).
SEVERE & NORMAL SERVICE DEFINITIONS
NOTE: Use the Severe Service schedule if the vehicle to be serviced
is operated under ANY (one or more) of these conditions:
Service is recommended at mileage intervals based on vehicle
operation and engine type. Service schedules are based on the
following primary operating conditions:
Normal Service
* Driven More Than 10 Miles Daily
* No Operating Conditions From Severe Service Schedule
Severe Service (Unique Driving Conditions)
* Towing A Trailer, Using A Camper Or Car Top Carrier
* Repeated Short Trips Less Than 5 Miles When Temperatures Are
Below Freezing
* Extensive Idling Conditions (Taxi Or Delivery Type Service)
* Operating On Dusty, Rough, Muddy Or Salt Spread Roads
SEVERE SERVICE REQUIREMENTS (PERFORM W/SERVICE SCHEDULES)
NOTE: The following services are to be performed on vehicles
subjected to severe service. See SEVERE & NORMAL SERVICE
DEFINITIONS. This service is to be performed in addition
to the normal services listed in the NORMAL MAINTENANCE
SERVICE SCHEDULES.
SEVERE SERVICE CONDITIONS/ACTIONS TABLE
Condition Action Item Perform Every (1)
Towing A Trailer, Replace Engine Oil & 5,000 Miles or 6 Months . Using A Camper Or Filter
Car Top Carrier
Replace Transmission 20,000 Miles or 24 Months
. Fluid
Replace Differential 20,000 Miles or 24 Months
 Fluid
Repeated Short Replace Engine Oil & 5,000 Miles or 6 Months
Trips Less Than 5  Filter
Miles When .
Temperatures Are Replace Transmission 20,000 Miles or 24 Months
Below Freezing  Fluid
 Fluid
Extensive Idling Replace Engine Oil & 5,000 Miles or 6 Months
Conditions (Taxi  Filter
Or Delivery Type .
Service) Replace Transmission 20,000 Miles or 24 Months
 Fluid
 Fluid
Operating On Replace Engine Oil & 5,000 Miles or 6 Months
Dusty, Rough,  Filter
Muddy Or Salt .
Spread Roads Replace Transmission 20,000 Miles or 24 Months
 Fluid
 Fluid
(1) - Perform these services at the mileage or number of months
(since the last time), whichever comes first.
NORMAL MAINTENANCE SERVICE SCHEDULES (NON-TURBO)
The following service schedules refer to vehicles driven
under normal operating conditions. For vehicles driven under severe
conditions, additional services may be necessary. See SEVERE SERVICE
REQUIREMENTS (PERFORM W/SERVICE SCHEDULES) above in this article for
additional service requirements.
7500 MILE (12,000 KM) SERVICE
Service Or Inspect
Change Engine Oil
Change Oil Filter
Lubrication Specifications
Application Specification
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
C) .................. SAE 10W-30 API SG .
Maximum Temperature .
Less Than 0
F (-18
C) ...................... SAE 5W-30 API SG
Fluid Capacities
Application (1) Quantity
 Engine Oil (2)
4A-FE ........................................ 3.4 Qts. (3.2L)
5S-FE (W/O Oil Cooler) ....................... 4.2 Qts. (4.1L)
5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L)
(1) - Capacities are recommended or calculated levels. Always use . dipstick (if available) to measure level. .
(2) - Includes filter change.
15,000 MILE (24,000 KM) SERVICE
Service Or Inspect
Verify Last Major Service Was Performed
 Brake Lining & Drums
 Brake Pads & Discs
 Brake Line Pipes & Hoses
 Steering Linkage
 Drive Shaft Boots
 Ball Joints & Dust Covers
 Transaxle Fluid
 Steering Gear Housing
Replace
Engine Oil & Filter
Automatic Transaxle .............................. Dexron-II ATF
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Manual Transaxle
2WD (1990) ......................................... Dexron-II . 2WD (1991-96) ..................... SAE 75W-90 (1)(2) API GL-3
(1) - If API-GL-3 is unavailable, API GL-4 or GL-5 may be used.
(2) - If there are questions concerning the correct type of fluid
 for Celica 2WD Manual Transaxle, see Toyota Tech Service . Bulletin VOL. 10, 043 December 1991.
Fluid Capacities
Automatic Transmission ......................... 3.5 Qts. (3.3L)
 Engine Oil (2)
Manual Transmission ............................ 2.7 Qts. (2.6L)
Service Labor Times
Application Hours
1.6L 4A-FE ................................................. 1.5
2.2L 5S-FE EFI ............................................. 1.5
22,500 MILE (36,000 KM) SERVICE
Service Or Inspect
Replace
 Change Engine Oil
 Change Oil Filter
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Fluid Capacities
 Engine Oil (2)
5S-FE (W/ Oil Cooler) ........................ 4.5 Qts. (4.2L) .
30,000 MILE (48,000 KM) SERVICE
Service Or Inspect
Exhaust Pipes & Mountings
 Idle Speed (4A-FE Engines)
 Fuel Line & Connections
 Brake Pads & Discs
Steering Linkage
 Drive Shaft Boots
 Transaxle Fluid
Replace
 Engine Oil & Filter
 Air Filter
Spark Plugs
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Manual Transaxle
Fluid Capacities
 Engine Oil (2)
Service Labor Times
Application Hours
1.6L 4A-FE ................................................. 2.0
2.2L 5S-FE EFI ............................................. 2.0
37,500 MILE (60,000 KM) SERVICE
Service Or Inspect
Replace
 Change Engine Oil
 Change Oil Filter
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Fluid Capacities
 Engine Oil (2)
45,000 MILE (72,000 KM) SERVICE
Service Or Inspect
 Brake Pads & Discs
 Steering Linkage
Drive Shaft Boots
 Transaxle Fluid
Replace
 Engine Oil & Filter
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Manual Transaxle
Fluid Capacities
 Engine Oil (2)
52,500 MILE (84,000 KM) SERVICE
Service Or Inspect
Replace
 Change Engine Oil
 Change Oil Filter
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature . Less Than 0
F (-18
Fluid Capacities
 Engine Oil (2)
60,000 MILE (96,000 KM) SERVICE
Service Or Inspect
 Valve Clearance
 Drive Belts
Idle Speed
Charcoal Canister
Brake Pads & Discs
Steering Linkage
Drive Shaft Boots
Transaxle Fluid
Replace
Engine Oil & Filter
Air Filter
Fuel Tank Cap Gasket
Camshaft Timing Belt (Severe Service)
Spark Plugs
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Manual Transaxle
Fluid Capacities
 Engine Oil (2)
Service Labor Times
Application (1) Hours
1.6L 4A-FE ................................................. 4.5
2.2L 5S-FE EFI ............................................. 4.5
(1) - Add 2.3 hours to replace camshaft timing belt.
67,500 MILE (108,000 KM) SERVICE
Service Or Inspect
Replace
 Change Engine Oil
 Change Oil Filter
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Fluid Capacities
 Engine Oil (2)
75,000 MILE (120,000 KM) SERVICE
Service Or Inspect
 Brake Pads & Discs
 Steering Linkage
 Drive Shaft Boots
Replace
 Engine Oil & Filter
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Manual Transaxle
Fluid Capacities
 Engine Oil (2)
Service Labor Times
Application Hours
82,500 MILE (132,000 KM) SERVICE
Service Or Inspect
Replace
Change Engine Oil
Change Oil Filter
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Less Than 0
F (-18
Fluid Capacities
 Engine Oil (2)
90,000 MILE (144,000 KM) SERVICE
Service Or Inspect
Brake Pads & Discs
Steering Linkage
Drive Shaft Boots
Transaxle Fluid
Replace
Engine Oil & Filter
Air Filter
Spark Plugs
Engine Oil
Minimum Temperature
Greater Than 0
F (-18
Maximum Temperature
Less Than 0
F (-18
Manual Transaxle
Fluid Capacities
 Engine Oil (2)
Service Labor Times
Application Hours
1.6L 4A-FE ................................................. 2.0 . 2.2L 5S-FE EFI ............................................. 2.0
97,500 MILE (156,000 KM) SERVICE
Service Or Inspect
This post has been edited by macavely: Jan 5, 2006 - 5:25 AM
post Jan 5, 2006 - 8:35 AM
o0black0o
Joined Jul 14, '05
From Spring, Texas
Awsome, thank you so much. Someone Sticky this!
post Jan 5, 2006 - 12:48 PM
elvasoshexai
Joined May 16, '05
From Toronto, Ontario
did it get cut off from being too long?
06 Civic EX
My For Sale Thread
post Jan 5, 2006 - 2:13 PM
wow mac, if you could only type that well without copying outta a book!!!! hahahahaha j/k man. awesome stuff, if we can get all the info in here, ill merge the posts, and sticky it =)
post Jan 6, 2006 - 4:20 PM
o0black0o
Joined Jul 14, '05
From Spring, Texas
Lo-Fi Version Time is now: February 17th, 2025 - 1:22 PM
