Tick tick hmmmm? |
Tick tick hmmmm? |
Jan 13, 2006 - 2:52 PM |
Enthusiast Joined Sep 5, '02 From Peoria, IL Currently Offline Reputation: 0 (0%) |
So this just started the other day, I need to get it fixed by next week when the guy flys up to pick up my car.
Ticking while in gear Its coming from under the front pass side, maybe right by the wheel. I can only really hear while in a drive thru or close to another car, but it ONLY does it while in gear and moving. If I put it in nuteral while Im moving doesnt do it. Sounds like a tick/vibration. Loud when in a drive thru. 5speed tranny Could it be an exhaust vidration or are we getting deeper?\ |
Jan 13, 2006 - 3:09 PM |
Enthusiast Joined Aug 21, '04 From New York City Currently Offline Reputation: 0 (0%) |
do you hear ticking while at idle? if you do it might be your valves ticking.
Jan 13, 2006 - 3:12 PM |
Enthusiast Joined Jul 3, '04 From Yakima, WA Currently Offline Reputation: 1 (100%) |
it could really be a number of things that are ticking... :-/. could be a bomb in your engine bay - who knows. if u say its comming from the passenger side, it could be nething related to suspension, but u said it only happens in gear during giving it some gas right? or is it idle in gear only
-------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Jan 13, 2006 - 3:15 PM |
Nope not at idle, only when in gear and driving low rpms. I know its not valves
Jan 13, 2006 - 3:18 PM |
how many miles on ur engine/car?
have u checked ur manifold gasket, along with all ur exhaust gaskets? -------------------- the 1/4 doesnt have patience for a ST.... so we make them ST-T's so atleast we'll sound good going slow.
Jan 13, 2006 - 3:23 PM |
110 on engine. Nope, havent checked those
Jan 13, 2006 - 3:26 PM |
well i have that same tick when at low rpms cuz i blow the manifold gasket when i put in the header... bad gasket im assuming but it sounds like a ticking tho.
Jan 13, 2006 - 3:41 PM |
jack up the car and look to see if your axels are not starting to go out
Jan 13, 2006 - 3:42 PM |
Enthusiast Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
It's a wheel bearing. Unless it speeds up while your sitting and reving the engine. Not really a simple fix, but pretty simple. A lot better than any internal thing. Take it too a parking lot and turn it one way and make circles, then turn it the other way. If it ticks when you turn to the left and circle, it's the right wheel, if it ticks when you turn right, it's the left wheel. Simple test. You're hearing it louder though a drive through because the sound is bouncing off the walls. Same things as how the car sounds louder in parking garage.
Jan 13, 2006 - 3:48 PM |
QUOTE(Bigmeanbulldog55 @ Jan 13, 2006 - 2:42 PM) [snapback]378176[/snapback] It's a wheel bearing. Unless it speeds up while your sitting and reving the engine. Not really a simple fix, but pretty simple. A lot better than any internal thing. Take it too a parking lot and turn it one way and make circles, then turn it the other way. If it ticks when you turn to the left and circle, it's the right wheel, if it ticks when you turn right, it's the left wheel. Simple test. You're hearing it louder though a drive through because the sound is bouncing off the walls. Same things as how the car sounds louder in parking garage. If Im rolling thru a drive thru it doesnt make the noise, only while in gear. If it is a wheel bearing I know for sure its coming from the pass front. Also, I can kinda here a lil vibration sound while on the interstate when I give it a good amount of gas |
Jan 13, 2006 - 4:24 PM |
QUOTE(Hart1583 @ Jan 13, 2006 - 3:48 PM) [snapback]378187[/snapback] If Im rolling thru a drive thru it doesnt make the noise, only while in gear. If it is a wheel bearing I know for sure its coming from the pass front. Also, I can kinda here a lil vibration sound while on the interstate when I give it a good amount of gas I'd go with what Lagos said then. Check both, sometimes things can be funny, and people will not quite understand. I've done that, I get it in my head that something is the problem, then I image all these signs of it. -------------------- Live Free, Be Happy
Lo-Fi Version | Time is now: January 9th, 2025 - 2:24 PM |
