> need indiglo help quick
post May 20, 2003 - 3:14 PM
popke23
Joined May 15, '03
From michigan
I just pulled my guages out to install my indiglos and I need to know what wire to splice into to light em up when the headlights are on... '95 celica st auto
Replies (1 - 2)
post May 20, 2003 - 4:13 PM
Cragspider
Joined Aug 30, '02
From Franklin,Tn
OK, there's a how to on this install, in the how to section. Its preaty straight forward on the install.
Bryan
post May 21, 2003 - 12:38 AM
neophile
Joined Nov 8, '02
From New Zealand
Hi
I took the easy way and ran the wires down and then through the plastic centre column (you can just tuck them underneath, no need to remove it) to the cigarette lighter.
It has a ring that lights up when the lights are turned on, so I just connected the indiglo wires to the +ve and -ve cables that power that light (make sure it's the light connections and not the lighter connections).
The plastic panel the cigarette lighter is attached to just pops out. My cables were long enough and it meant i didn't have to try and find the right wire to spice or unscrew/remove any major panels.
Lo-Fi Version Time is now: November 28th, 2024 - 4:26 PM
