Air Intake! |
Air Intake! |
Jan 20, 2006 - 11:03 PM |
Enthusiast Joined Jan 18, '06 Currently Offline Reputation: 0 (0%) |
i juz installed an air intake on my 97 celica st.....it fits and all but i have one problem, i dunt know where to connect the blue hose....where does it go? i cant find a hole to stick it in lol....someone please HELP!!
Jan 20, 2006 - 11:12 PM |
Enthusiast Joined Aug 16, '04 From Baton Rouge, LA Currently Offline Reputation: 0 (0%) |
Make a hole
Jan 21, 2006 - 1:22 AM |
Enthusiast Joined Jan 6, '06 From Tennessee Currently Offline Reputation: 0 (0%) |
Um. Which hose? On mine, I was forced to leave a hose loose. The "vital" hose is the crank case vent, which needs to go from the crank case to the intake pipe. I think the cleaner option is to install a catch tank. However, for the time being, I've just got a loose hose floating around in there.
Here's what my 99 GT had. On the stock intake pipe, there was the temp sensor, the tube coming from the crank case, and one going from the intake pipe down to somewhere, which I didn't bother to figure out. That's for tomorrow. As far as I know, the important thing to do is reinsert the temp sensor, and clamp the tube coming from the crank case to the intake pipe. This post has been edited by ZacMan1987: Jan 21, 2006 - 1:27 AM |
Jan 21, 2006 - 4:15 AM |
if your lazy, get a cheap breather filter from kragen.
Jan 21, 2006 - 11:08 PM |
Enthusiast Joined Mar 27, '04 Currently Offline Reputation: 14 (100%) |
thats how i set mine up... ~Daniel -------------------- ~Daniel~ No Longer Celica Owner.. moved on to a 03 WRX-EJ207
Jan 22, 2006 - 12:03 AM |
P.S. I'm assuming the rationale for running the CAI pipe outside like so many seem to do would be it keeps the pipe cooler? I just ran mine straight forward to the left of the battery, then down below the battery, but it does pick up a lot of heat from the exhaust manifold.
Jan 22, 2006 - 12:47 AM |
Enthusiast Joined Jun 12, '05 From Box Springs, GA Currently Offline Reputation: 0 (0%) |
Yup, that's the reason. The air inside the fender is cooler than in the engine compartment. That's why the stock "piping" is setup like that.
~bob -------------------- |
Lo-Fi Version | Time is now: November 30th, 2024 - 9:06 PM |
