![]() Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '05 From Toronto, Ontario Currently Offline Reputation: 8 (100%) ![]() |
uh is there a way to tell if they are truely brembo rotors or if somebody just put them in a brembo box?
Enthusiast Joined Jan 30, '06 From good old blighty Currently Offline Reputation: 0 (0%) ![]() |
No serial numbers to check out ??
failing that I'd go to a shop and look at Brembo rotors and then compare them with the ones in question. |
![]() Administrator ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '02 From Seattle, WA Currently Offline Reputation: 14 (100%) ![]() |
Brembo rotors have the Brembo logo and name machined into them.
There's one of my ST184 rotors.
![]() -------------------- New Toyota project coming soon...
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) ![]() |
Brembo also makes a cross drilled rotor. When coomer said that the brembo rotors have brembo on the side i looked at my cross drilled ones, and sure enough it does say brembo on them. But i can't get a pic i've ben trying to get a pic of the brembo on the sides. But it comes out blury.
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) ![]() |
i dont believe brembo makes cross drilled rotors for the 6gc. i think someone else drills them.
Nah brembo takes there stock replacement rotors and drills them..
I want to see it in their product list then. I'm not saying you're wrong I've just never seen proof.
ya understandable. But if someone tried to drill a rotor themself it would come out ruff as crap and would never work right. these holes are perfect. and not ruff at all. if you want i'll try and get a pic like coomers. and show they say brembo on them and show how smooth the holes are.
QUOTE(celiracer @ Feb 7, 2006 - 7:15 AM) [snapback]390124[/snapback] ya understandable. But if someone tried to drill a rotor themself it would come out ruff as crap and would never work right. these holes are perfect. and not ruff at all. if you want i'll try and get a pic like coomers. and show they say brembo on them and show how smooth the holes are. You should...and make sure you get the part number in the picture. It's a five-digit number I believe. -------------------- New Toyota project coming soon...
K. i'll try. so far everytime i take one it gets blury. but i'll keep trying
![]() But while im looking at yours coomer. Mine is a little diff. it says this. 12 02 A AA MINTH 26 MM and then says brembo. Doesn't have the numbers after brembo.?? Here is a pic. Not very good but u can see what it all says on the rotor.\ ![]() This post has been edited by celiracer: Feb 7, 2006 - 10:47 AM -------------------- ![]() |
Enthusiast ![]() Joined Jul 2, '05 From NYC Currently Offline Reputation: 0 (0%) ![]() |
brembo make drill rotors and slotted. they do not make cross drilled and slotted. when you see a brembo brake kit with both cross drilled and slotted. this means the owner got the rotors custom drilled.
ya Mine in the pic above. Are there brembo cross drilled rotors.
thanks for the info! i'll check that out when i pick it up tmr night
er.. on the side of one of my rear rotors it says:
02 04 D A MIN TH 9 MM... is that the right size for a 98 gt? on the brembo site it says for the rear the min thickness is 8mm.. -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) ![]() |
QUOTE(elvasoshexai @ Feb 9, 2006 - 7:19 PM) [snapback]391469[/snapback] er.. on the side of one of my rear rotors it says: 02 04 D A MIN TH 9 MM... is that the right size for a 98 gt? on the brembo site it says for the rear the min thickness is 8mm.. That's okay, 9mm is bigger than 8mm -------------------- Live Free, Be Happy
![]() Enthusiast ![]() ![]() Joined Jan 22, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) ![]() |
A lot of people can cross-drill and slot rotors near OEM finish, it depends on the equipment. It's not necessarily cheap to get rotors slotted or cross-drilled.
-------------------- www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS 15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2 |
keep in mind that cross drilled and slotted rotors are more abrasive then either or.
cross drilled and slotted-very abrasive drilled- abrasive slotted- not so abrasive this just means that you feel more "friction" on the brake pedal. |
QUOTE(RCTCelica @ Feb 10, 2006 - 1:42 PM) [snapback]391529[/snapback] keep in mind that cross drilled and slotted rotors are more abrasive then either or. cross drilled and slotted-very abrasive drilled- abrasive slotted- not so abrasive this just means that you feel more "friction" on the brake pedal. Also means you go through pads a helluva lot faster ![]() -------------------- www.tangcla.com - photography
![]() Enthusiast ![]() ![]() ![]() Joined Jan 16, '06 From Lima, ohio Currently Offline Reputation: 0 (0%) ![]() |
QUOTE(tangcla @ Feb 9, 2006 - 9:44 PM) [snapback]391532[/snapback] QUOTE(RCTCelica @ Feb 10, 2006 - 1:42 PM) [snapback]391529[/snapback] keep in mind that cross drilled and slotted rotors are more abrasive then either or. cross drilled and slotted-very abrasive drilled- abrasive slotted- not so abrasive this just means that you feel more "friction" on the brake pedal. Also means you go through pads a helluva lot faster ![]() this is true, the reason is because the slots also clean the break pads when you press the brakes This post has been edited by lilsteeg: Feb 11, 2006 - 9:37 PM |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) ![]() |
but can they warp faster then normal rotors?
Lo-Fi Version | Time is now: February 17th, 2025 - 12:47 PM |
