Factory Keyless Entry/Alarm Question, Can you make it beep on and off? |
Feb 9, 2006 - 6:19 PM |
Enthusiast Joined Feb 5, '06 From Westminster, Ca Currently Offline Reputation: 0 (0%) |
My celica still has the original factory keyless entry. When you lock the door, the lights flashes once. when you unlock the door, the lights flashes twice. is there a way to set it up so it makes noises when you lock and unlock the door? on most toyota's i've noticed that it has a quick beep to lock and a double beep to unlock.
Feb 9, 2006 - 6:55 PM |
Enthusiast Joined Feb 9, '03 From Sioux falls, South Dakota Currently Offline Reputation: 1 (100%) |
mine honks the smae amount as the light flashes, if the alarm has gone off it honks three times, it also honks three times if a door or window is open. what does your remote look like, i have a gulf states package on my car and the alarm was part of that package.
-Aaron- -------------------- |
Feb 9, 2006 - 7:13 PM |
QUOTE(afroman @ Feb 9, 2006 - 6:55 PM) [snapback]391453[/snapback] mine honks the smae amount as the light flashes, if the alarm has gone off it honks three times, it also honks three times if a door or window is open. what does your remote look like, i have a gulf states package on my car and the alarm was part of that package. -Aaron- mines is nothing likes yours. it doesn't honk at all when you arm or disarm. And if a door is left opened when you try to arm it, all it does is make this really loud annoying high tone noise that doesn't stop until you secure that door. the remote looks something like... an egg shape? two bottoms, one on top of the other. the top one is the main one that arms and disarms. the bottom one i honestly have no idea what it does. there's the toyota logo on the bottom of the remote. and on the back in little prints on the bottom it has the fcc code thing and says made in japan (JDM remote! ) in fact... the remote looks EXACTLY like this! |
Feb 9, 2006 - 7:20 PM |
ya that looks nothin like mine, mine has the key and fob as one, if i can get a camera ill take a pic.
edit: this is kinda what mine looks like -Aaron- This post has been edited by afroman: Feb 9, 2006 - 7:27 PM -------------------- |
Feb 9, 2006 - 7:28 PM |
whoa, that's totally different. i dont' think that's a factory alarm. looks sorta aftermarket to me...
Feb 9, 2006 - 7:33 PM |
its toyota, it has a part # i have to order them form the dealership and they are $95. When i took it in they told me it was a gulf states only pacakge. its almost the same as the lexus G470 fob
Feb 9, 2006 - 8:02 PM |
hmm... i guess it is stock then. the remote is obviously different and the way u said the alarm works is different too. so must be a whole completely different alarm system. anyone have more info on.... the west coast system?
Feb 9, 2006 - 10:46 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
Idea: Find the keyless brain, test to see which one outputs to the parking lights, diode isolate it, throw in a relay and connect it to your horn or a siren.
Feb 9, 2006 - 11:33 PM |
QUOTE(Cutrara @ Feb 9, 2006 - 10:46 PM) [snapback]391565[/snapback] Idea: Find the keyless brain, test to see which one outputs to the parking lights, diode isolate it, throw in a relay and connect it to your horn or a siren. hmmm.... that would definitely work. still perfer to just have it setup to work if that's an option. does anyone know where the brian for the alarm is located? |
Feb 10, 2006 - 12:07 AM |
Enthusiast Joined Jan 25, '06 From Marlton, NJ Currently Offline Reputation: 0 (0%) |
yea i also have the same question becuz my car will beeep at the most random clicks, but i really want it to be constant beeping when i turn on/off the alarm
Feb 10, 2006 - 12:35 AM |
QUOTE(Kamakaze @ Feb 10, 2006 - 12:07 AM) [snapback]391607[/snapback] yea i also have the same question becuz my car will beeep at the most random clicks, but i really want it to be constant beeping when i turn on/off the alarm is it a factory alarm? which remote do you have? |
Feb 10, 2006 - 7:05 AM |
Enthusiast Joined Mar 25, '05 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
My one has the factory alarm.
I dont know if it's different from yours since I'm in Australia. Mine use to be silent when arming and disarming. But then I read the manual and it showed me how to make it beep everytime it armed and disarmed. My alarm remote is a separate unit from the key. It has two button - Unlock/Disarm - Lock/Arm/Panic And inside the car it also has a button and an LED in the dash. If it sound similar to mine, I'll look up the manual and show you how to do it. -------------------- 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
Feb 10, 2006 - 12:08 PM |
QUOTE(CelicaZR @ Feb 10, 2006 - 7:05 AM) [snapback]391699[/snapback] My one has the factory alarm. I dont know if it's different from yours since I'm in Australia. Mine use to be silent when arming and disarming. But then I read the manual and it showed me how to make it beep everytime it armed and disarmed. My alarm remote is a separate unit from the key. It has two button - Unlock/Disarm - Lock/Arm/Panic And inside the car it also has a button and an LED in the dash. If it sound similar to mine, I'll look up the manual and show you how to do it. agh, close..... mines uses the same buttom to arm and disarm... the remote looks EXACTLY as the picture that i posted. i should just call the dealership |
Feb 10, 2006 - 6:31 PM |
Enthusiast Joined May 20, '05 From San Diego, California Currently Offline Reputation: 0 (0%) |
QUOTE(Kamakaze @ Feb 10, 2006 - 12:07 AM) [snapback]391607[/snapback] yea i also have the same question becuz my car will beeep at the most random clicks, but i really want it to be constant beeping when i turn on/off the alarm mine too... except sometimes it beeps when it's really cold. -------------------- |
Feb 10, 2006 - 7:22 PM |
Enthusiast Joined Oct 5, '05 From NE Currently Offline Reputation: 6 (100%) |
Mine beeps sometimes and doesn't beep its weird. Wish i new how to make it work how its supposed to all the time.
Feb 11, 2006 - 9:05 PM |
QUOTE(Princess_Sparco @ Feb 11, 2006 - 4:08 AM) [snapback]391772[/snapback] QUOTE(CelicaZR @ Feb 10, 2006 - 7:05 AM) [snapback]391699[/snapback] My one has the factory alarm. I dont know if it's different from yours since I'm in Australia. Mine use to be silent when arming and disarming. But then I read the manual and it showed me how to make it beep everytime it armed and disarmed. My alarm remote is a separate unit from the key. It has two button - Unlock/Disarm - Lock/Arm/Panic And inside the car it also has a button and an LED in the dash. If it sound similar to mine, I'll look up the manual and show you how to do it. agh, close..... mines uses the same buttom to arm and disarm... the remote looks EXACTLY as the picture that i posted. i should just call the dealership My friend has the same button as your. But not the same remote. I'll look up the instruction later for ya. -------------------- 98 ST204 ZR - Black Beauty - Roaming the streets of Sydney 73 TA22 LT - Tiffany Blue - Mint Classic Weekend Cruiser 75 TA22 LT - Snow White - Mint Classic Weekend Cruiser 77 RA28 LT - Flubber Green - Mint Classic Weekend Cruiser 94 MX-5 NA8 Clubman - Red Racer - Looking for corners WIP Project: 69 RT40 Corona, 2nd WIP Project: 66 RT40 1600s Corona 86 Corona RT142 - Daily Driver 6GC 4 Life Baby!!! |
Feb 13, 2006 - 5:12 PM |
BUMP
Feb 13, 2006 - 5:17 PM |
QUOTE(Cutrara @ Feb 9, 2006 - 10:46 PM) [snapback]391565[/snapback] Idea: Find the keyless brain, test to see which one outputs to the parking lights, diode isolate it, throw in a relay and connect it to your horn or a siren. Just do this it will cost you like $5 if you hook it up to your horn. -------------------- |
Feb 13, 2006 - 7:46 PM |
Enthusiast Joined Feb 25, '04 From Fairfield, CA Currently Offline Reputation: 0 (0%) |
http://www.4runners.org/articles/rs3000/
This link has the users manual for the factory alarm system for the 98 toyotas. Should be straight forward. |
Feb 14, 2006 - 10:23 AM |
Enthusiast Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) |
does factory alarm have valet, because in valet mode, the car just flashes and not beeps, take off valet and the beeps will be back
Lo-Fi Version | Time is now: November 24th, 2024 - 10:01 AM |
