Fuel pump |
Fuel pump |
Feb 12, 2006 - 1:50 AM |
Enthusiast Joined Aug 14, '05 From St. Paul, MN(USA) Currently Offline Reputation: 8 (100%) |
I was wondering if the stock fuel pump from the GT will work with the 3sgte motor? because im broke and cant offrd a walbor 255 fuel pump. And whats the pros/cons running stock fuel pump?
Feb 12, 2006 - 6:28 AM |
the stock FP will NOT provide enough fuel for the swap.
13.6@108MPH, 5SFTE Powered |
Feb 12, 2006 - 6:32 AM |
Enthusiast Joined Jan 17, '04 From Illinois Currently Offline Reputation: 0 (0%) |
If you are too broke for a $90 fuel pump, you are too too broke for a swap.
-------------------- QUOTE(lagos @ Jul 10, 2006 - 1:55 PM) [snapback]454118[/snapback] i know your trying to do the right thing for your motor, but this is one of those times where you should just trust the guys who have had their swaps for a while and have done a ton of research into this. |
Feb 12, 2006 - 1:11 PM |
QUOTE(jgreening @ Feb 12, 2006 - 6:32 AM) [snapback]392559[/snapback] If you are too broke for a $90 fuel pump, you are too too broke for a swap. No the swap made me broke so don't get it wrong. Motor in the shop right now. |
Feb 12, 2006 - 4:20 PM |
you cant do something as big as a swap, and then cheap out on a fuel pump that costs 100bucks.
Feb 12, 2006 - 4:25 PM |
Lets try this another way. The stock fuel pump will not deliver enough fuel to the engine under all conditions, particularly more than stock boost. When any of these conditions occurs, you run the risk of running lean and blowing your engine. Now really, can you afford not to get a fuel pump?
Feb 12, 2006 - 5:04 PM |
QUOTE(jgreening @ Feb 12, 2006 - 4:25 PM) [snapback]392687[/snapback] Lets try this another way. The stock fuel pump will not deliver enough fuel to the engine under all conditions, particularly more than stock boost. When any of these conditions occurs, you run the risk of running lean and blowing your engine. Now really, can you afford not to get a fuel pump? well i just bought one off ebay today so guys don't worry no more. I bought a walbro 255 fuel pump. So is it hard to install the fuel pump? I might just bring it to the shop (where my engine is at now) and tell them to install too. |
Feb 12, 2006 - 5:23 PM |
Enthusiast Joined Jan 22, '06 From Melbourne, Australia Currently Offline Reputation: 0 (0%) |
it's a cheap part, you may as well do it
-------------------- www.tangcla.com - photography
Canon EOS 5D Mark II | EOS 1D Mark II N | 16-35mm f/2.8L |24-70mm f/2.8L | 70-200mm f/2.8L IS 15mm f/2.8 fisheye | 85mm f/1.8 | 100mm f/2.8 macro | 580EX-II x2 |
Lo-Fi Version | Time is now: November 30th, 2024 - 12:27 AM |
