> passenger airbag, can you take the panel off?
post May 26, 2003 - 7:44 PM
Chrobis
Joined Apr 15, '03
From San Jose, CA, USA
well the post title pretty much sums it up. I would like to paint the airbag pannel on the passenger side but was scared to pull it off thinking the airbag might deploy.
Replies (1 - 9)
post May 26, 2003 - 7:54 PM
Guest_Matthew_*
i would say
i wouldnt try to take it off.
if you are afraid of it hitting you and could care less if it goes off. get one of your friends to do it. otherwise i wouldnt do it
oh and on your sig where do i get that plastic model?
post May 26, 2003 - 8:47 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
i got my gt-four model from e-bay wink.gif $20+shipping
post May 28, 2003 - 1:47 AM
Travis
Joined Mar 24, '03
From virginia
Whoa! before you go yanking that **** off, disconnect you're battery, and wait like 5 mins. the bag shouldn't deploy, but there's a safety relay that takes several mins. to shut down, then go pulling a jerking all you want, found the info trying to change out steering wheels, and getting around the driver's bag, in case your wondering!
post Jun 22, 2003 - 7:16 PM
pimpjester
Joined Dec 23, '02
From Joplin, Missouri
The air bag hasn't deployed on me yet i have my cover to where i can lift the front side for extra storage area.
post Jun 22, 2003 - 7:45 PM
QUOTE (pimpjester @ Jun 22, 2003 - 4:30 PM)
Wait, so you store stuff in the air bag compartment? If so, that could easily kill your passenger if you got in even a minor fenderbender.
post Jun 23, 2003 - 2:20 AM
Russkiy
Joined Nov 18, '02
to discharge the air bags you have to disconnect the battery for not less than 90 seconds. After that you can do whatever you want with them. If you want to take the whole air bag out, you going to have to take the whole dash board off. I've dane it on my car.
good luck.
post Jun 23, 2003 - 2:22 AM
Russkiy
Joined Nov 18, '02
also, i dont know about any extra storage room under the airbag cover. there is an actual airbag sits, there is no spase at all.
post Jun 23, 2003 - 9:39 AM
Charlie97L
From North Bethesda, MD
QUOTE (Chrobis @ May 26, 2003 - 6:58 PM)
that's not the panel, it's the airbag. just be aware. and also, it's vinyl, not plastic, so if you paint it, use vinyl dye otherwise it will look like crap.
1994 Lexus ES300
1989 Supra Turbo
1990 RHD ST185RC - JDM Spec
post Jul 2, 2003 - 11:27 PM
pimpjester
Joined Dec 23, '02
Ok heres the deal when i got my body kit put on the front sensor for the air bags was removed and the unit did not all of a sudden shoot out or the light stay on all the time. So i removed the brain for the air bags and left the harness for now as far as the passenger air bag i completely removed it from the car (about 10#'s lighter) and i have no problems with the drivers side either.
I did however keep the cover for the passenger side and i remounted the cover itself and mounted a 7.2 lcd on the bottom of it and its a great spot for a tv.
Lo-Fi Version Time is now: February 20th, 2025 - 1:39 PM
