> wiring and sizing
post Feb 23, 2006 - 11:37 PM
ok for wiring harness (body and engine) wat gauge wire should i use?
and for things like normal speakers, neons, gauges, ect.. what should i use
Replies (1 - 3)
post Feb 25, 2006 - 10:35 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
Neons draw very minimal current.. So anything is really fine, 16Ga or something simlar. The same thing with speakers, 14-16Ga will be fine. You may want to run 12Ga, but I don't really see the advantage, other than less resistance, and *maybe* better SQ. Subs I run 10Ga, to be safe.
Obviously for running power/ground cable to amps, you need much thicker cable. Up to around 1000W rms, you'd be fine with 4Ga cable.
Engine wires, I wouldnt have the slightest.
This post has been edited by ShadowFX: Feb 25, 2006 - 10:40 AM
post Feb 25, 2006 - 11:37 AM
I'd replicate the wire sizing that Toyota uses from the factory for the body/engine harness.
post Feb 27, 2006 - 7:29 PM
K-ESD
Joined May 5, '05
From New-Brunswick Canada
http://www.bcae1.com/wire.htm
----------------------6GC's FIRST V6----------------------
JDM 96 MR2-T Faster - 94 Celica GT 3MZFE Funner - 99 Rav 4 AWD Handy
Lo-Fi Version Time is now: November 27th, 2024 - 8:27 PM
