> HELP dead cylinder
post Feb 25, 2006 - 1:16 PM
Elevindie
Joined Jan 6, '06
From Michigan
ok this is what is going on. i have a 94 celica st (7afe) and the #1 cyl. is not firing. Fuel is getting to it, there is compression (250 psi), there is a spark, but when i remove the spark plug and place it in the boot for seeing if there is a spark by grounding it to the block, it fires from the threads!!! i have changed the spark plugs, and i have swapped them with other cylinders. i have swapped wires. then today i jumped the diagnostic port t1 and te1, and a code flashed. the code is continual flashing, what could this cody be, and what is my problem. Please help. thanks
Replies (1 - 11)
post Feb 25, 2006 - 1:22 PM
StreetRacing10PS...
Joined Oct 10, '04
From New Jersey
250PSi is a lil high for the 7A. my compression is usually around 180PSI
post Feb 25, 2006 - 8:22 PM
Dunners
Joined Oct 25, '05
From Brisbane, Australia
Doesn't continuous flashing mean that it has no codes to throw? I could be wrong. good luck.
post Feb 25, 2006 - 8:33 PM
jayi12-15psi
Joined Jan 9, '03
From St. Louis
I think on my 5s w/ 190k miles had a compression of only 170. I'm no mechanic, but that seems a little off.
post Feb 25, 2006 - 8:37 PM
CelicaZR
Joined Mar 25, '05
From Sydney, Australia
I agree with SR10PSI should be arounbd 180 PSI.
What did all the other cylinders get?
6GC 4 Life Baby!!!
post Feb 25, 2006 - 10:03 PM
TrdKing
Joined Feb 16, '05
From Brantford, Ontario, Canada
how are you grounding the spark plug?
post Feb 26, 2006 - 10:57 AM
Elevindie
Joined Jan 6, '06
From Michigan
maybe that 250 psi is a little high, maybe it was read wrong. i am grounding the spark plug to the bolt on top of the valve cover. also yesterday i ran the car for about 5 minutes with the dead cylinder, and there wasnt any gas on the plug. but when i placed my ear right next to the injector, i can hear it opening and closing. Now i am thinking that it might be a fuel problem. BUT the other 3 cylinders are getting fuel. hmmmm leave me some feedback. Thanks
post Feb 26, 2006 - 1:14 PM
TrdKing
Joined Feb 16, '05
If the spark is going from the threads of the plug then it is taking the easiest ground out. When the plug and wire is in the whole it maybe grounding to the tube. See if you can get the plug to spark like it is supposed to.
if you want to you can use a stethescope to actually hear if the injectors are actually opening or closing
has the motor been sitting long or something
post Feb 26, 2006 - 7:06 PM
Elevindie
Joined Jan 6, '06
From Michigan
the wires are just fine. because i swapped them with a different cylinder, and it works perfectly. i will see if i can get a stethescope from somewhere, but i just used my ear. i got really close to it, and i could hear it opening and closing. then i moved my ear down to the next injector, to make sure i wasnt hearing that one.
post Feb 27, 2006 - 7:55 PM
Elevindie
Joined Jan 6, '06
From Michigan
i think i found the problem. i switched injectors today, and the cylinder that has the supposed bad injector, did not fire. so it is the injector. does anyone know where to get some aftermarket injectors? thanks for all the help!
post Feb 27, 2006 - 8:02 PM
TrdKing
Joined Feb 16, '05
I dont know about aftermarket but toyota always has them and if you want to you could try a wrecking yard
post Mar 1, 2006 - 9:33 PM
Elevindie
Joined Jan 6, '06
From Michigan
i was searching the web, i found a web site named fuelinjectordirect has them for my st. i remaned from Napa was like $70, and new was like $160. brand new from a toyota dealership was like $240. the website has them for like $65, and they have a lifetime warrenty.
Lo-Fi Version Time is now: January 12th, 2025 - 7:08 AM
