TRD Vs. Stock Shifter Comparisons, Thought I'd take some pics |
Mar 20, 2006 - 11:15 PM |
Enthusiast Joined Jun 25, '05 From Fort Wayne, IN Currently Offline Reputation: 14 (100%) |
Ok, here we go:
TRD is on the Left, Stock is on the right. VERY similar housings. Here you can see the difference in the height of the stick. Here you can see the difference in the shape of the stick. Note the location of the retainer for the top of the boot. It's lower on the TRD stick because the shifter knob sits MUCH lower on the stick than the stock one does. This is a good shot of how much is taken off the top of the TRD stick. Lastly, you can see here that the ball end of the stick has been lowered. Essentially, the TRD stick has been shortened and bent slightly differently than the stock, but more importantly the pivot point has been lowered which has a dramatic effect on the shortening of the throws. Just some FYI information I thought would satisfy some curious minds and some pics I hadn't seen posted nor explained. Just hoping to help out here. -------------------- |
Mar 20, 2006 - 11:37 PM |
Enthusiast Joined Mar 12, '05 From ATL, Georgia Currently Offline Reputation: 0 (0%) |
nice!
Mar 20, 2006 - 11:42 PM |
Enthusiast Joined Jun 1, '03 From WV Currently Offline Reputation: 2 (100%) |
No wonder the TRD on costs so much. The 7th gen shifter just comes with the rod and bushings. It's nice to finally see a comparison.
Mar 21, 2006 - 12:00 AM |
Enthusiast Joined Jun 29, '03 Currently Offline Reputation: 0 (0%) |
This is a perfect buy if you're doing a auto to manual conversion.
Mar 21, 2006 - 10:04 PM |
Enthusiast Joined May 6, '05 From PA Currently Offline Reputation: 4 (100%) |
QUOTE(Chanh55 @ Mar 21, 2006 - 12:00 AM) [snapback]410772[/snapback] This is a perfect buy if you're doing a auto to manual conversion. Did you buy it? -------------------- |
Mar 21, 2006 - 10:38 PM |
Enthusiast Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
almost makes me wish i had 150 bucks to spend.
-------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Mar 22, 2006 - 12:08 AM |
QUOTE(Cutrara @ Mar 21, 2006 - 7:04 PM) [snapback]411149[/snapback] QUOTE(Chanh55 @ Mar 21, 2006 - 12:00 AM) [snapback]410772[/snapback] This is a perfect buy if you're doing a auto to manual conversion. Did you buy it? Yeah I bought it... I should change my Celica details since I just converted her to manual. |
Mar 22, 2006 - 12:16 AM |
Enthusiast Joined Sep 5, '02 From Winter Haven, FL Currently Offline Reputation: 11 (100%) |
QUOTE Here you can see the difference in the shape of the stick. Note the location of the retainer for the top of the boot. It's lower on the TRD stick because the shifter knob sits MUCH lower on the stick than the stock one does. That would be one very deep shift knob for that too be true The plastic retainer is too low on your TRD shifter, probably got pushed down at some point along the way. You can adjust it to fit what ever style knob you want. It will likely be the same distance from the threads to the retainer as the stock one goes. BTW, don't forget about the metal spacers that go on the bottom of the shifter housing. I was reinstalling mine a while back and forgot about them, needless to say it didn't work too well. The end of the stick will bottom out against the floor |
Mar 22, 2006 - 3:07 AM |
Enthusiast Joined Mar 19, '06 From Rocklin, CA Currently Offline Reputation: 0 (0%) |
Who's done this mod? How do you like it?
Mar 22, 2006 - 6:07 AM |
QUOTE(Xpander @ Mar 22, 2006 - 12:16 AM) [snapback]411207[/snapback] QUOTE Here you can see the difference in the shape of the stick. Note the location of the retainer for the top of the boot. It's lower on the TRD stick because the shifter knob sits MUCH lower on the stick than the stock one does. That would be one very deep shift knob for that too be true The plastic retainer is too low on your TRD shifter, probably got pushed down at some point along the way. You can adjust it to fit what ever style knob you want. It will likely be the same distance from the threads to the retainer as the stock one goes. BTW, don't forget about the metal spacers that go on the bottom of the shifter housing. I was reinstalling mine a while back and forgot about them, needless to say it didn't work too well. The end of the stick will bottom out against the floor Ummmm......yeah, it IS one very deep shift knob. That plastic clip on the TRD stick was in a specific spot and held there in a retainer groove. The end of the threads in the shifter knob are JUST under the top of the knob on the inside, and if you've ever looked at a stock vs. TRD shifter knob you'll notice that the TRD is the tailshaft style knob while the stock is just the top round knob itself. In other words, yes, that plastic clip is in the correct location, yes, the TRD knob is very deep by design. Everything sits in the car 100% lined up with no changes to what was shown in the pics. I'll try to get pics tonight of the TRD vs. Stock knob, for reference. Good call on the spacers. That was immediately aparrent when I had the shifter sitting in there without them. They are a must if you're installing this shifter. I should have gotten a pic of that. QUOTE(Jeremiah @ Mar 22, 2006 - 3:07 AM) [snapback]411266[/snapback] Who's done this mod? How do you like it? I instantly noticed a difference in how shifting felt, and my wife absolutely loves it. *Edited* I didn't mean to sound like a prick in my initial response. This post has been edited by Fastbird: Mar 22, 2006 - 8:29 AM -------------------- |
Mar 22, 2006 - 7:14 AM |
ive had mine for a couple years now,
IMO its the best one, bar none. ive tried the TWM and 7th gen, both are too notchy and short for my taste. -------------------- Former Team 5SFTE pro member ;)
13.6@108MPH, 5SFTE Powered |
Mar 22, 2006 - 12:25 PM |
Its cool Fastbird. I never had a stock shifter and knob since I converted mine from automatic, I figured it would be the same
I love the feel of the TRD shifter, its tight and has a solid feel to it. Although 1st to 2nd seems a bit long. |
Mar 23, 2006 - 8:45 AM |
Enthusiast Joined Nov 16, '04 From UK Currently Offline Reputation: 0 (0%) |
QUOTE(Jeremiah @ Mar 22, 2006 - 8:07 AM) [snapback]411266[/snapback] Who's done this mod? How do you like it? Yes and I like it very much. -------------------- JDM ST205
Blitz Spec NUR Exhaust, somewhere over $1000 Needing another one 18000 miles later, bloody annoying. |
Apr 2, 2006 - 2:03 AM |
Enthusiast Joined Dec 3, '05 From San Jose, CA Currently Offline Reputation: 0 (0%) |
i was thinking of getting this...is it that much better than the stock shifter?
Apr 2, 2006 - 10:03 AM |
QUOTE(hashmaster52 @ Apr 2, 2006 - 2:03 AM) [snapback]416661[/snapback] i was thinking of getting this...is it that much better than the stock shifter? Yes. We love it. Shorter throws, better feel. My ONLY complaint is that the shift knob is a little too small for my taste. -------------------- |
Apr 3, 2006 - 7:48 AM |
Enthusiast Joined Nov 7, '05 From Brisbane, Australia Currently Offline Reputation: 0 (0%) |
i'm tossing up whether to get a TRD or a TWM,
TRD short shifter in australia is like $450AUD or $300US is that normal or expensive |
Apr 3, 2006 - 8:17 AM |
QUOTE(MaX @ Apr 3, 2006 - 8:48 AM) [snapback]417137[/snapback] i'm tossing up whether to get a TRD or a TWM, TRD short shifter in australia is like $450AUD or $300US is that normal or expensive Expensive. I paid $200 shipped for mine and feel like I overpaid. Guys have been known to get them for about $150-175 USD. -------------------- |
Apr 3, 2006 - 4:30 PM |
Enthusiast Joined Oct 30, '03 From IL Currently Offline Reputation: 15 (100%) |
QUOTE(Fastbird @ Apr 2, 2006 - 10:03 AM) [snapback]416707[/snapback] My ONLY complaint is that the shift knob is a little too small for my taste. is the shift knob that much smaller then the stock one? its the one that says TRD on the side right? Doesn't this come with the package? -------------------- PROJECT 6TH GEN
<FS: Things up for grabs> <Progress> |
Apr 3, 2006 - 5:29 PM |
QUOTE(Shigexile @ Apr 3, 2006 - 5:30 PM) [snapback]417315[/snapback] QUOTE(Fastbird @ Apr 2, 2006 - 10:03 AM) [snapback]416707[/snapback] My ONLY complaint is that the shift knob is a little too small for my taste. is the shift knob that much smaller then the stock one? its the one that says TRD on the side right? Doesn't this come with the package? Yeah, it's the TRD Shifter Knob, and it's noticably smaller than the stock shift knob. And yes, it comes with the setup. -------------------- |
Lo-Fi Version | Time is now: December 2nd, 2024 - 12:36 AM |
